ATMEL ATF2500C
Topics related to the Dataman 48Pro+
CHERON Maxime
ATMEL ATF2500C
Postby CHERON Maxime » 26 Feb 2015 14:21
Hello Mr Smith
Here are the differences between programming file from Dataman 48+ and from DATA I/O programmer
Dataman Programmer
BAD
QF71816*
F0*
L000000 01111111111111111011111111111111* »
MASTER
Data I/O Programmer
GOOD
« QP0040*
QF71816*
F0 *
L000000 11111111111111111011111111111111 *»
The difference has been noticed that is 0 instead of a 1 on the fisrt data.
I used FF blanking mode.
The checksum is different with -1 in value for exemple :
4582 is good and is the value expected
and with the Dataman programmer, i have 4581.
Thank you in advance
Best regards
Maxime CHERON
Re: ATMEL ATF2500C
Postby Dataman (Neil Parker) » 26 Feb 2015 15:40
Hello Maxime,
Can you provide some more information about the situation.
Where are you getting the data, from a file on the PC or from reading a chip?
Can you provide a copy of this file? (email to [email protected])
What is the result of reading a known good chip using the Dataman? And also what is the result if this data is used to program a new device? Does it work OK?
If you are also able to provide a problem report showing your actions it would be helpful. Please use the (Help | "Create problem report") feature in the software and email the resulting log file to [email protected] for analysis.
Dataman Programmers.
CHERON Maxime
Re: ATMEL ATF2500C
Postby CHERON Maxime » 27 Feb 2015 08:51
Hello Mr PARKER,
The G1387C01_master.JED file is the MASTER the U1_DATAMAN_CCEBh_with FF.JED is the file reading after the programing .for program a chip, and
I am unfortunately not able to make a problem report file because the programmer is not close to me.
I can’t see a good component with the Dataman programmer , we made two tests , one with a master component and a second from a source file.
In case 2 , if the first fuse is "1" in file or component MASTER, it remains at " 0" in the new component. then the component is bad ( checksum -1)
then , if the first fuse is "0" in the file or component MASTER, it remains at " 0" in the new component. and the component is good ( checksum ok)
Regards
Re: ATMEL ATF2500C
Postby Dataman (Neil Parker) » 13 Mar 2015 15:07
Hello Maxime,
Based on information received from another customer regarding this device our engineers have been able to implement an improvement in the algorithm for the Atmel ATF2500C device.
URL: http://www.dataman.com/downloads/dl/fil ... ftware.zip
Return to “Dataman 48Pro+”
