New software - Version 3.17
Postby Dataman (Daniel Smith) » 02 Sep 2015 16:03
DIL48/LQFP32 ZIF Kinetis-1 adapter, added support
DIL48/LQFP64 ZIF MC56F-1 adapter, added support
DIL48/QFP128 ZIF-CS HD64-3 adapter, added support
DIL32/TSOP32 ZIF 12.4mm NOR-1 adapter, added support
Fujitsu MB85R4001A, bug fixed
