sector programing on the 48pro
Postby Guest » 10 Nov 2011 11:05
Is there a way to write only certain sectors is the flash memory (intel 28FxxxJ3A Strata Flash)
The flash im working with is write protected and I only need to write a couple of the sectors that are not write protected. ie. the sectors 1,2,32 are write protected can erase the other sectors but to write to those sectors that I erased I can not program by a full write. Not to mention the time that is used to attempt to write to write protected sectors is killing me.
Thanks
Re: sector programing on the 48pro
Postby Dataman (Neil Parker) » 17 May 2013 15:55
On the Dataman-48Pro and other models from this range you can use the from-to feature to target only the sectors you wish to write to. If they are not consecutive, then you can use the multiproject feature where you would create a separate project for each sector you wish to write to and then combine the projects into a multiproject file which will then run each project in turn to achieve the overall goal. More information on the milti-project feature can be found in the online help topics from within the control software.
