New software - Version 3.23
Postby Dataman (Daniel Smith) » 08 Apr 2016 14:27
Modified selftest (changed voltage in test of limiting diodes)
Adapter DIL48/QFN56-2.02 ZIF CY-3, interface modified
Adapter DIL40/QFP144 ZIF LPC-1, insertion test bug fixed
