PC to S4 Hex file problem
Postby Guest » 14 Nov 2011 16:43
I'm having a problem with a hex file being changed from my original file. When I load the hex file into the S4 it is entirely different than my original hex file. I have setup the S4 for Intel files. What is causing this problem? Here is a sample of my file.
Actual
:040000000034003494
:08000800A000030E8312A10009
:100010000608E03AE7000F08E0000E08E100031DC3
:1000200013280F08E00067082039031921288316D8
:100030000608DF39860083126108BA006008B9003B
:10004000B20A6708403903192F2883160608BF39FA
S4 Memory
:2000000000340034FFFFFFFFA000030E8312A1000608E03AE7000F08E0000E08E100031D78
:2000200013280F08E000670820390319212883160608DF39860083126108BA006008B90043
:20004000B20A6708403903192F2883160608BF39860083126108CA006008C900C20A670830
:20006000803903193E28831606087F39860083126108DA006008D900D20A3E2806080B08E4
:20008000FE398B00210E8300A00E200E0900640083160030850086008700880089008312A2
:2000A000003085008600870088008900E0308600831600308500ED3086001F3088000030DF
Greg3000
Re: PC to S4 Hex file problem
Postby Dataman (Neil Parker) » 14 Nov 2011 16:43
Hi Greg,
The S4 is using a different formatting and Intel data record than the data sent from the PC.
The 2 files are identical in terms of data, they are just created in different formats.
The Intel Hex file format allows that.
Hope this helps.
Hi Neil,
I need to reload library ROM to my Dataman S4. It displays:
Dataman S4 BIOS 1.2
512K BYTES RAM
NO LIBRARY LOADED.
I need to do PC to Dataman S4 library ROM loading, please get me through the steps.
Rgds,
GoddyN
Hello GoddyN,
There is an application note on this very task which can be found on our website here. It is the tenth application note down the list.
If you encounter any problems at any stage, please let me know and I will be happy to help.
Dataman Tech Support
Return to “Dataman S4”
