Using low voltage to read Old/Bad Eproms?
Postby Guest » 14 Nov 2011 16:53
I read somewhere that it may be possible to read data from an old / bad EPROM by lowering the voltage. That some Eproms will read OK at 4 volts and not at 5.
Any body heard of this?
And if so - how to do it using the S4?
Any hints much appreciated!
/Peter
Re: Using low voltage to read Old/Bad Eproms?
Postby Guest » 14 Nov 2011 16:54
Hi Peter
From what i know the S4 lowest voltage is 5v as i know it wont do flash chips at 3.3v as the hardware in the S4 just won't do it. as it is a good few years old and back then 5v was the standard, and hence has now been discontinued by Dataman for which i for one am sad about.
Maybe they now do a usb programmer that the supply voltage can be changed on, but perhaps Neil will know the answer to that one
hope that helps alittle
Cheers
Andrew
Postby Dataman (Neil Parker) » 14 Nov 2011 16:55
Hello Peter,
Andrew is correct in that the S4 is not able to generate voltages lower than 5v.
I can however offer you a solution: the Dataman-40Pro.
The 40Pro is one of our lowest cost programmers. As its name suggests it is specialised in supporting memory devices. A full device support list and the full product specifications can be found on our website www.dataman.com
The 40Pro is a PC based USB programmer which supports over 24,800 devices(08/2010). It comes with all the cables and software needed to start programming straight out of the box. The software is updated on a monthly basis.
Specifically, the feature that will help you is the "Generic-EPROM" selection. Simply select a device of the correct size from this catagory and you will then be able to modify the following parameters:
As you can see, the VCC voltage can be set anywhere from 2-7v and you can also tweak the current values and basic timing parameters in order to try and get a good read from a device.
The 40Pro is available from stock and comes with a 3 year warranty as standard. We also offer a 30 day money back guarantee, so if the programmer doesn't do what you need, simply return it for a full refund.
Best regards
Return to “Dataman S4”
