New software - Version 2.40
Postby Dataman (Daniel Smith) » 16 Nov 2011 12:08
Version 2.40 features the following amendments:
Altera EPM7xxxAE, checksum calculation bug fixed
AMD/Lattice/Vantis MACH215, reading/programming timing bug fixed
Atmel AT90USB162 [MLF32] and AT90USB82 [MLF32] overcurrent at pin 18 error fixed
Atmel AT24C16B [dBGA2-8U3-1], wrong programming adapter information fixed
Atmel AT17Nxxx, programming parameters bug fixed
Cypress CY8C24894, ID code bug fixed
Cypress CY7C64215, checksum verification at serialization mode bug fixed
Cypress CY7C63813, checksum at read chip procedure bug fixed
Freescale MC9S12XDT256, memory map correction
Microchip PIC24FJ64GA010, configuration bits programming bug fixed
NEC uPD78F9210-uPD78F9212, bug fixed
NEC uPD78F9177A, serialization bug fixed
Xicor X24042, insertion test bug fixed
Altera EPM7128S [TQFP100], increasing of overcurrent protection limits
Atmel AT24xxx, AT34xxx, AT93xxx a AT25xxx in package dBGA2-8, edit package name and backward project compatibility correction
Atmel AT89S52 (ISP), programming improvements
Atmel AT91SAM7SE512, programming improvements
Cypress CY7C6xxxx BlankCheck improved
Cypress CY826233, initialization sequence improved
Intel RC28F320J3C and PC28F320J3C, erase procedure improved
Lattice LC4512V [FPBGA256], modification of power-up/power-down routines, improving of programming/verification yield
Lattice LCMXOxxx [FPBGA256], improving of insertion test procedure
Macronix MX29LV320Cx buffer checksum calculation modification, checksum now include Secured Silicon sector data
Microchip PIC16F627, PIC16F628, PIC16F737/747/767/777, PIC16F74/76, PIC16F818/819, PIC16F87/88, PIC16F83/84/84A, PIC16F870/871/872/873/874, PIC16F874A/873A, ID area programming improvement
Microchip PIC16F946, user ID area programming improved
Microchip PIC16F628A, programming routine modification
Microchip PIC18F6xJxx, power-on sequence improved
Motorola MC68HC705C8A, change of Option register programming
Motorola HC11, project files load improved
Freescale MC9S12D64, programming improvement
Philips/NXP LPC23xx, programming speed increased
Renesas M306N5FCTFP, verify, read and blank check improved
Samsung S3F84K4, power up procedure improved
Samsung K8P3215, erase procedure improved
Silicon Laboratories C8051F41x, erase procedure improved
Spansion S71GL064A programming speed increased
Spansion S29GL032AxxFxxSx, read procedure improved
Spansion S29GL128N, S29GL256N, S29GL512N, SecSi area programming procedure in x16 mode improved
STM M25P32, M25P64, M25P128, improving erase/programming speed
Winbond W29C040, boot block unlock procedure added
Winbond W79E659, programming Security register improved
Xilinx XC2C32A [QFG32], improving of ID check routine
Xilinx XC95216, XC95288 [HQFP208], improving of programming and insertion test procedure
Xilinx XC2Cxxx/A - improving of ID check routine
Modifications for all chips, programmed by DIL48/PQFP144 ZIF ST10-2 programming adapter
Buffer organization for flash devices with special area (SecSi, HiROM, OTP region...) was changed
NAND Flash memory optimization
