New software - Version 2.65
Postby Dataman (Daniel Smith) » 17 Nov 2011 11:28
Version 2.65 features the following amendments:
Amic A29L320A, sectors group count bug fixed
Atmel AVR32 family, Erase bug fixed
Atmel AT32UC3A3, Erase bug fixed
Atmel, ATtiny261/461/861 [MLF20], pinout bug fixed
Atmel ATxmega128A3, Flash range fixed
Atmel ATxmega192A3, EEPROM range fixed
Cypress CY8CTMG200, fixed verification errors in multiprogramming systems
Dallas/Maxim DS2505, DS2506, USB specific algorithm bug fixed
EON EN29LV320D, device memory size bug fixed
Freescale Semic. MC9S08SV16, power up/down bug fixed
Freescale Semic. MC9S08SVxx, MC9S08SHxx, algorithm bug fixed
Freescale Semic./Motorola MC56F835x, memory map and buffer allocation error fixed
Freescale Semic./Motorola MC56F8xxx, fixed data dependent bug of algorithm
Freescale Semic./Motorola MC908QC16 (ISP 5-wire), fixed instability bug of calibration algorithm
Lattice M4A3-128/64 [TQFP100],M4A5-128/64 [TQFP100], power up routine bug fixed
Macronix MX25L12855E [TFBGA24], (DualSPI) and (QuadSPI), temporarily removed from support
Microchip dsPIC33FJxxx, PIC24Hj, PIC24FJ Family, power-up procedure bug fixed
Microchip PIC12F629, power-up procedure bug fixed
Microchip PIC18F13K50, PIC18F14K50, configuration bits bug fixed
NEC uPD78F9088, verification procedure bug fixed
Philips P89C58B, programming bug fixed
Samsung K5W1G13ACB [FBGA153]: Unexpected error 1 [IEC:97, D:3D] fixed
Silicon Laborat. C8051F502, erase bug fixed
STMicroelectronics, STM32F10x family, Unexpected error 1 [IEC:0, D:6E] fixed
STMicroelectronics STM8S207M8T [LQFP80], insertion test bug fixed
Xilinx XC18Vxx, XCFxxS/P (ISP), ID check bug fixed
Xilinx XCF02S (ISP), ID check bug fixed
NAND flash devices: Verify errors logging bug fixed in Tolerant verify mode
Special adapters "xxx SFlash-1" and "xxx SFlash-2", incorrect display of count of inserted devices fixed
Altera EPM240 [FBGA100], improving of overcurrent protection system
Altera EPM5064, change in device name from EPM5064 to EPM5064 [0.65um] for 0.65um revision, adding of information for chip revision differentiation (0.8um and 0.65um)
AMD/Lattice/Vantis MACH211SP (ISP), improving of programming action
Atmel ATF16V8CZ, improving of programming action
Eon EN39SL160H [TSOP48], EN39SL160L [TSOP48], info about required converter updated
EXEL XLS2816A, programming algo improvement
Finisar XFP, added programming of special area
Finisar XFP, automatically calculation of Check code CC_EXT added after each operation with buffer
Freescale Semic./Motorola HC08 ISP, minor improvements
Intel PC28F256P30B [Easy BGA64], verify operation improved
Lattice GAL22V10B-Q, change in device name from GAL22V10B-QP to GAL22V10B-Q
Lattice ispPACPOWR, change in device name from ispPACPOWR to ispPAC-POWR
Lattice LC4xxxB/C/V/ZC [TQFP176], improving of overcurrent protection system
Macronix MX29F800CT [TSOP48], MX29F800CB [TSOP48], info about required converter updated
Microchip dsPIC33FJ64MC508, PIC24HJ128GP506, added Device ID check after programming procedure
NAND01GW3B2CZA [VFBGA63] (KAON-01), algorithm modification as per additional user request
Numonyx M25P32-V, improvement of ID check
NXP/Philips LPC13xx, inZIF algorithm speed up
NXP/Philips LPC13xx, LPC17xx, LPC21xx, LPC22xx, LPc23xx, LPC24xx ISP algorithm speed up
Philips/NXP TDA12156H/N3 [QFP80], improving of entering pgm. mode
Renesas Technology R5F364AENFA (ISP), programming speed increased
SST SST25VF016B, programming speed up
Spansion S29GL032NxxBxx04 [FBGA48], programming procedure modification
Spansion S29GL512PxxFxxS1 [FBGA64], programming procedure modification
STMicroelectronics STM32F10x CPU families: improving operation speed (22-35% speedup)
STMicroelectronics STM8L101K3T [LQFP32] power-up modification
TI (TMS) MSP430F2132 (ISP-BSL), added message "PASSWORD Mismatch" if the password was entered incorrectly (program action)
Xilinx XC18Vxx, XCFxxS/P (ISP), improving of programming action
Xilinx XCF02S (ISP), improving of programming action
Custom algorithms LGE-09 ~ LGE-13: invalid blocks detection modification as per user request
NAND flash devices: Check Max. Allowed Number of Invalid Blocks in Device feature added
PLD/CFG (ISP), adding of "Disable supply voltage test" option for ISP actions to disable voltage test, if necessary
DIL48/QFN68 ZIF-CS PLD-1, improving of programming parameters assignment
