New software - Version 2.49
Postby Dataman (Daniel Smith) » 17 Nov 2011 16:45
Microchip PIC18F24J10, power-up procedure bug fixed
Renesas R4F2461, bug fixed
SST SST25WFxxx, Atmel AT25DF081, removed from support
