New software - Version 2.67
Postby Dataman (Daniel Smith) » 18 Nov 2011 12:23
Version 2.67 features the following amendments:
AMD Am29BDD160GT [PQFP80], Am29BDD160GB [PQFP80], device suffix information in dialog "Device info" fixed
Atmel AT90PWM81, the faulty setting of fuse bits PSCRRB and PSCINRB fixed
Atmel AT90PWMxxx, bodlevel values bug fixed
Atmel ATmega32M1/32C1/64M1/64C1, bodlevel + bootsize values bug fixed
Atmel ATmega640/1280/2560, flash size range bug fixed
Atmel ATtiny48/88 (ISP), loading of frequency value from the project file bug fixed
Eon EN29PL032 [TSOP48], overcurrent error fixed
Freescale Semic., Motorola HCS12 in-ZIF, range check error fixed
Freescale Semic., Motorola MC68HC908QBx [TSSOP16], trimming algorithm bug fixed
Microchip dsPIC33FJ, PIC24FJ, PIC24HJ Family, configuration bits verification bug fixed
Microchip PIC16F182x, load/save hex file bug fixed
Microchip PIC18F2xx0/4xx0 Family, programming procedure bug fixed
Renesas M34283G2GP, programming protect bit bug fixed
STMicroelectronics STM8S105C4T, serialization function bug fixed
Terra Semicond. devices, sector erase error fixed
Xilinx XC95144XL/XV [CSP144], insertion test bug fixed
Zilog Z86E30, overcurrent error fixed
Cypress CY8C20466 [QFN32], power-up sequence improved
EON EN29PL032 and EN71PL03280, "buffer mode" programming replaced by "word mode" programming due to EON Silicon Solution, Inc. recommendation
Hitachi HD64F3029F, programming procedure modified
Hitachi HN27C64, ID check disabled, programming algo improved
Infineon TC1767, loading of IntelHex/MotorolaHex files improved
Infineon XC164xx, programming algorithm improved
Intel PH28F640W18B [VFBGA56], program operation reliability improved
Lattice ispLSI2032, pgm. parameters assignment improvement
Lattice M4A5-32/32, pgm. parameters assignment improvement
Maxim MAXQ610, "Device start" and "Device end" settings added, programming algorithm improved
Microchip PIC16F716, erase procedure improved
Microchip PIC16F7x7, power-up procedure improved
Microchip PIC18Fxxx, buffer allocation improved
NEC uPD70F3380, programming speed increased
Samsung, K5D12571CA and K5D12121CA, programming algorithm improved
Samsung, K9F1208U0C, programming algorithm improved
Siemens SAB88C166, programming algorithm improved
Siemens XC164xx, programming algorithm improved
Silicon7 SV7E3204UTA [FBGA56 7x9], ID check modified
Silicon Laborat. C8051F412, programming procedure modified
Spansion S71WS128PC0HF3S [FBGA84], programming procedure modified
STMicroelectronics STR7, STR9 and STM32 families, Automatic YES! pins detection improved
SyncMOS SM59264, programming algorithm improved
Xilinx XC95144XL/XV [CSP144], pgm. parameters assignment improvement
Add blank spare area function added to file load dialog for NAND flash devices
File load speed improvement for NAND flash devices up to 16Gbit
Linux MTD driver compatible support released for NAND flash devices
SVF Player algorithm improvement
Hitachi HD6473837F [QFP100], change of programming adapter name to DIL32/QFP100 ZIF-CS HS3836ESF01H
