hi for all
hi for all
Postby Guest » 10 Nov 2011 12:30
i have dataman 48Pro+ and dataman 48UXP
and i have chip sst25vf016b
and at26df161a
and en25b16
all spi flash
i can read and write it ok
but i have Problem now because
i have chips at26df161a and en25b16 and sst25vf016b
when i read it and write it and put it in Board not work ok
and the Machine factroy the lcd of machine show code not true serial number Invalid and im use same number of original chip
when i put original chip it work ok
i see datasheet for chips i see you can make protection how i can read chips and unlock protection
by my dataman progrmmer
oneday
Re: hi for all
Postby Dataman (Neil Parker) » 10 Nov 2011 12:30
Hello oneday,
Can you provide more information about what you are trying to do?
I can see no problems with reading data from a master SST25VF016B device and programming the same data into another SST25VF016B device. This should work as expected as long as the devices are good.
You may run into problems if you are reading data from a master SST25VF016B device and programming it into a AT26DF161A device, as they may not be pin or electrically compatible.
I will try to help you further once I have more information.
Dataman Programmers.
Re: hi for all
hi m Neil Parker im reading form master sst39vf016b and programming salve sst39vf016b but when i test salve the lcd of machine show me serial number invalid when i using master the lcd of machin show me sn (9080675431) and work ok
how i can edit serail number in flash i see some progrmmer can edit serail number but im not have one
oneday
Re: hi for all
Postby Dataman (Neil Parker) » 10 Nov 2011 12:31
Hello oneday
I can not understand this situation. This chip is straight forward Flash, it has no security or sector protect.
I am afraid that I do not know why the copy chip does not work at all in your application.
It is nothing to do with the programmer if you can read/write to the chip without errors.
I am sorry that we could not be of more help on this occasion.
Technical Support
