Version 2.87 features the following amendments:
Added indicator ** (buffer was modified) after file name saved to "Original file:" information included in project file(s)
Fixed bug for device programmer with USB high speed connectivity when connected to USB3.0 hosts
Fixed bug in reading device settings of type Int64 from ini/prj files
Fixed "Load file" operation blocking for some special devices, to prevent the blocking remains after selecting of new device, that has "Load file" operation allowed
Fixed problem with project file checksum in "Save project" dialog to protect project programming device by its checksum required
For Custom generator Serialization mode is increased timeout of waiting for Custom generator result serial file from 5 up to 15 seconds
In dialog "Save project" was old setting "Require project file checksum before first programming" changed to new setting "Require project file unique ID before first programming"
In PG4UWMC added new menu command "Options | Save options"
Fixed from-file serialization in PG4UWMC to block next device programming, when end of serialization file was reached
Fixed in PG4UWMC - improved indicator of CPU usage to prevent showing of incorrect values of CPU usage on multicore processors
Altera MAX 7000S, addition of Enable JTAG BST Support bit description
Altera MAX V [FBGA256], improving of insertion test and pin assignment
Atmel ATmega128RFA1, power-on sequence improved
Atmel ATmega128RFA1, the power-on sequence optimization
Atmel ATmega161 in ZIF, removed unsubstantiated option "override EESAVE setting" in the "device operation options" window (ALT+O)
Atmel AVR8 family in ZIF, removed obligatory blank check if an erase before programming is enabled
Atmel AVRtiny series inZIF, erase function modified
Atmel/Inside Secure AT90SCR100H, Power-up sequence modified
eMMC devices, read sector groups protect status stability improved
HCS12xx [QFP80] family adapter support added, DIL48/QFP80 ZIF-CS HCS12-2
Lattice ispPAC-POWR607, improving of blank check test action
LatticeXP, improving of erase action
Macronix MX29GL256Fx, programming Solid write Protection mode and Password Protection mode modified
Maxim MAX966x. MAX967x, loading files improved
Microchip PIC12F609, description of MCLR pin in Alt+S menu improved
Microchip PIC16F737, verify procedure improved
Microchip PIC18F2221, PIC18F4221, configuration mask improved
Microchip PIC18FxxKxx (ISP), PIC18FxxKxx (ISP-ext.VDD), programming speed increased
Microchip PIC18FxxKxx (ISP-ext.VDD), added Description of ISP connector pins
Micron N25Q256Ax3E [DFN8 8x6] (Quad I/O), read/verify operations improved
NEC uPD78F051xA (ISP-UART), added option of setting the oscillator frequencies
NEC/Renesas uPD70F3634, programming speed increased
Nordic nRF24LE1, erasing algorithm improvement
Numonyx N25Q256Ax3E [VDFPN8] (Quad I/O), read/verify operations improved
Numonyx PC28F00BM29EWH [BGA64], verify procedure improved
Huawei SD5000V100 [LQFP176], buffer organization changed
Huawei SD5000V200 [TFBGA208], programming of Bootcode area feature added
Huawei SD5000V200 [TFBGA208], programming procedures improved
Silicon Laborat. C8051F761, programming speed increased
Spansion S29GL128NxxTFx01 [TSOP56], verify procedure improved
STMicroelectronics STM32Fxxx in ISP mode: NRST signal strengthened
STMicroelectronics STM8L101F1U [UQFN20], programming option bytes modified
STMicroelectronics STM8L151K4U [XQFN32], programming option bytes modified
STMicroelectronics STM8T141, power-up procedure improved
TI (TMS) LM3S315, LM3S615, improving of verify after programming action
TI (TMS) LM3S9B96, power-up sequence improved
Atmel AT90s2343, reading bug of the fuse bits and lock bits in the reading procedure fixed
Atmel ATxmegaA1/A3 (ISP-JTAG), user page size bug fixed
Atmel AVR8 series ISP, double blank check bug in programming sequence fixed
Atmel/Inside Secure AT90SCR100H, wrong BODENABLE fuse bit description fixed
eMMC devices, save buffer bug fixed
eMMC devices, project compatibility bug fixed
Exar XRP7714, identification of programming adapter bug fixed
Huawei SD5000V200 [TFBGA208], bug in programming operation of Bootcode area fixed
Huawei SD5000V200 [TFBGA208], erase procedure bug fixed
Lattice Power Manager, ispPAC30, ID code bug fixed
Microchip HCS301, HCS302, Alt+S menu bug fixed, removed item En_Key, should be Reserved
Microchip PIC12F6xx, PIC16F6xx, set of PWRTE configuration bit bug fixed
Microchip PIC18F6xK22, PIC18F8xK22, set of configuration bit BBSIZ0 bug fixed
NAND flash devices: "Unexpected error 1 [IEC:3, D:02]" after new invalid block is detected during programming bug fixed
NEC/Renesas uPD70F334x, uPD70F335x, uPD70F336x, programming of security fuses bug fixed
NEC/Renesas uPD70F3628, uPD70F3372, synchronization procedure bug fixed
NEC/Renesas uPD78F071x, synchronization procedure bug fixed
NXP/Philips LPC1311/01 and LPC1313/01, ID check bug fixed
Spansion S25FLxxxS, S70FLxxxS family, sector erase error fixed
TI (TMS) LM3S2793, Automatic YES bug fixed, programming improved
TI (TMS) LM3S5R36, LM3S5T36, erase bug fixed
TI (TMS) MSP430F23x0, programming JTAG fuse bug fixed
Weltrend WT51F516 [SSOP20], insertion test bug fixed
New software - Version 2.87
Postby Dataman (Daniel Smith) » 02 Mar 2012 15:47
