ST92F150JDV
TS33DDI
ST92F150JDV
Postby TS33DDI » 11 May 2012 15:58
Hi all,
I have a MCU with part number ST92F150JDV and don't have the DIL48/PQFP100 ZIF ST92Fxxx adapter for it. Is there any way to read and write to the chip using other device setups or could dataman support this in ISP mode?
Thank you!
Re: ST92F150JDV
Postby Dataman (Neil Parker) » 15 May 2012 10:27
Hello TS33DDI,
I will get our engineers to check the datasheet for this device to see of it supports ISP programming mode and also if we are able to add the ISP support.
I will post an update when I have more information.
Regards
Dataman
Re: ST92F150JDV
Postby Dataman (Neil Parker) » 15 May 2012 14:06
Hello TS33DDI,
The ST92F150JDV device requires significant time and resources to add the ISP programming support. Due to the very small amount of interest in this solution we cannot justify it at this time. I can only advise you to use parallel programming via the ZIF socket.
The suitable adaptor socket is: DIL48/PQFP100 ZIF ST92Fxxx
Regards
Dataman
TS33DDI
Re: ST92F150JDV
Postby TS33DDI » 13 Jun 2012 13:45
Was really looking forward to ISP support for this particular chip but if that's the case it's understandable. Thanks for taking a look at it anyways.
TS33DDI
Re: ST92F150JDV
Postby TS33DDI » 06 Aug 2012 19:42
A few more questions, will this adapter work for other same chip packaging(TQFP/PQFP) by other manufacturers? According to the adapter info, this adapter is device specific to ST92Fxxx mcus, is there a universal adapter you could recommend besides a device specific or can you provide pin outs for the dataman 48pro+ programmer's zif and the chip?
