New software - Version 2.91
Postby Dataman (Daniel Smith) » 20 Aug 2012 16:42
Version 2.91 features the following amendments:
Improved settings for Automatic YES!
Fixed problem with data buffer after loading of multi-project
Fixed problem with checksum when saving project file after loading data file, the project could not be correctly read, and report Checksum mismatch error
Fixed problem with load project error (project could not be loaded) for older projects and Sandisk SDIN5D2 devices
Fixed problem with load projects for SVF devices
Fixed problem with remote control running device operation for multi-project
Fixed text fonts for Japanese (and other Asian languages) in device hint window, displayed after new device is selected
Fixed PG4UWMC error "Attempt to write byte to read-only buffer 1..." for NXP LPC2138 devices
Fixed PG4UWMC problem with menu command "Device | Select device & Create project"
Altera EPCSxxx, POF file loading improved
Altera EPCSxxx, adding information about ignoring of unknown tag=35, based on the manufacturer recommendation
Amic A29801TM [PSOP44], power-up sequence modified
Amic A29801UM [PSOP44], power-up sequence modified
Atmel ATtiny24A/44A/84A, power-on sequence improved
Atmel ATxmega64B3 [TQFP64], ATxmega64B1 [TQFP100], suitable programming adapter changed
Atmel AVR-8 family (ISP-SPI), Default Oscillator frequency settings changed
Fairchild NM93C46T, improving of pin assignment
Freescale Semic. MC68HC705C8A, power-up sequence improved
Freescale Semic. MC68HC711Ex, length of EPROM programming pulse changed
Micron MT29F16G08ABABAWP [TSOP48] (LSI-01), algorithm modification upon new customer info
Micron N25Q256Ax1E [SO16W], improving of programming action
Micron PC28F00AG18F [EasyBGA64], verify operation improved
Micron PC28F128G18F [EasyBGA64], programming adapter test improved
Mitsubishi/Renesas M16C/62P, option Block A programming added
Samsung K9F5608Q0C [FBGA63], read and verify operation reliability improved
Spansion S29CD016JxxQxx11 [PQFP80], power-up sequence modified
Spansion S29GL064NxxTxxV2 [TSOP56], power-up sequence improved
Spansion S29GL256NxxTFxR2 [TSOP56] x16, verify procedure improved
STMicroelectronics STM32F10xx8 and STM32F10xxB, in-ZIF programming time reduction
STMicroelectronics STM32F4xxVx [LQFP100], dual support released (rev=A and rev<>A)
TI (TMS) LM3S1N16, erase time changed
TI (TMS) UCD90120A [QFN64] (D), verify operation reliability improved
Toshiba TMP47P443VM [SOP28], insertion test modified
Toshiba TMPM324F10FG [LQFP144], verify operation improved
Winbond W25Q128FVTC [TFBGA24], W25Q128FVTB [TFBGA24], changed device names and backward project compatibility correction
ZMD U631H64, Power-on sequence improved
Actel A3P125 [QFN132], device overcurrent error bug fixed
Atmel ATtiny13, ATtiny25/45, Unexpected error bug fixed when erase and "Override EESAVE fuse"
Atmel ATtiny20 [BGA15], communication error fixed
Atmel ATtiny48/88 [UFBGA32], pinout bug fixed
DIL40/TQFP64 ZIF PIC-3, Automatic Yes! bug fixed
DIL48/QFP52 ZIF NEC-1, Automatic YES! bug fixed
eMMC devices, programming permanent sector groups protect bug fixed
Energy Micro EFM32G230F128 [QFN64], "Connecting with target device - error!" bug fixed
Eon Silicon Sol. EN25Q16A, EN25Q16A (DualSPI), protected memory setting bug fixed
Freescale Semic. MC68HC705JJ/JP7, Blank Programming Parameter fixed
Freescale Semic. MC9S12XS256 [QFP80], Automatic YES fixed
Lattice MachXO2, Part number description bug fixed
Microchip PIC18LF4431, programming procedure bug fixed
Micron M29W256GLxxZS [LBGA64], ID check bug fixed
NEC/Renesas uPD78F1201, uPD78F1203, Unexpected error 1 [IEC:1, D:5F]! bug fixed
Nuvoton N79E8432A [SOP16], configuration bit read bug fixed
Samsung K9G8G08U0B [TSOP48] (USD-01), invalid blocks treatment bug fixed
SanDisk SDIN4C2, reading protect status bug fixed
