I'm writing an expect script to drive my S4. I'd like to set the handshaking to ensure that an upload from the S4 to the host doesn't overflow the host buffers. In the documentation for the setup key in the manual, it says "This key has no terminal equivalent. File type, baud rate and handshake have separate terminal commands." I see the BA and FF commands, but I don't see a command for the handshaking. Clues?
Terminal command to set handshaking?
Re: Terminal command to set handshaking?
Dear Guest,
I am afraid that it is not possible to modify the S4 handshaking parameters using the terminal commands. If you wish to modify this value then you will have to do it using the S4 keypad. The value will be remembered so you should only have to make the change once until the library is reloaded or the unit reset.
If you have any further questions, please let me know.
