New software - Version 3.01
Postby Dataman (Daniel Smith) » 01 Nov 2013 16:33
New option for From-file serialization added: "Comment used lines (serial records) in main serialization file"
Fixed Custom generator serialization error "Fatal Error: Required address is out of range for current buffer."
Fixed loss of PG4UW application focus during startup of the application
In PG4UWMC standalone mode fixed error "Access violation" when trying to update software by menu Help | Update software
Actel AGL250V5 [FBGA144], improving of overcurrent protection system
Atmel AVR8 family (ISP-JTAG), power-up sequences modified
Azoteq IQS127, improved device settings
BGA-Bottom-229, Automatic YES! improved
Cypress CY8C20334, insertion test modified
Cypress CY8C21645, device ID check modified
Eon EN39SL800 [TFBGA48], ID check procedure and power-up sequence modified
For devices in FBGA63 and CSP63 packages, supported with BGA-Bottom-1 + BGA-Top-109 ZIF-CS alternative added BGA-Bottom-1 + BGA-Top-185 ZIF
Freescale Kinetis K family, changed erase algorithm
Hitachi/Renesas HD6473032, programming sequence optimized and stabilized
Macronix MX25U25635F, according to datasheet MAR/06/2013 REV. 1.1, removed Write Protection Selection (WPSEL), Advanced Sector Protection
Microchip PIC10F2xx, set of configuration bits MCLR improved
Misubishi/Renesas M3826AEFGP [QFP100], insertion test and programming sequence modified
Nand flash devices, max. supported partitions count for MBN files increased to 64
Nand flash devices, MXMP-01 custom devices features availability changed upon user request
OKI MR27V32xx [PSOP44], programming speed improvement
STMicroelectronics STM32F2xx, STM32F4xx, Option Bytes programming procedure modification
STMicroelectronics STM8S005C6T, option bytes modified
TI (TMS) BQ26100, added programming of keys
TI (TMS) MSP430F51xx, read/verify procedure improved
Atmel AT89C51CC02, Device Synchronization Error bug fixed
Atmel AVR32 family, bad secure state settings description bug fixed
Atmel AVR8 family (ISP-JTAG), reading of calibration value bug fixed
Azoteq IQS128, blank check bug fixed
Cypress CY8C20637, communication error fixed
eMMC devices, end address verification bug fixed
Freescale MC68HC908GZ16 [LQFP32], programming error fixed
Freescale SCKL26Z128CLL4 [LQFP100], programming error fixed
Fujitsu MB95F63x, access to flash memory address 0xFFBB bug fixed
GigaDevice Semic. MD25D40, MD25D80, partname fixed (was GD25D40, GD25D80)
Holtek HT81R36, bug fixed
IR IR3570B, device ID check bug fixed
Macronix MX25L25635F, MX25U25635F, MX25L12873F, MX25L12873F, MX25L25735F, 'Lock-down secured OTP bit' programming fixed
Macronix MX66L51235F [SOP16] (Quad I/O), 'Lock-down secured OTP bit' programming fixed
Maxim MAXQ6xx, verification procedure bug fixed
Microchip dsPIC30F5011, erase procedure bug fixed
Microchip dsPIC33EP32MC20x, configuration bits verification bug fixed
Microchip dsPIC33EPxxxGP50x, dsPIC33EPxxxMC20x/50x, PIC24EPxxxGP/MC20x, FCKSM bit field combination of "10" enabled for use in FOSC configuration register
Microchip dsPIC33EPxxxGP50x, dsPIC33EPxxxMC20x/50x, PIC24EPxxxGP/MC20x, protected device report bug fixed in case of GWRP is set
Microchip PIC32MX360F512L, program lock up during programming action fixed
Nand flash device, Load binary file with Add blank spare area feature enabled bug fixed
NEC/Renesas uPD70F3107, power-on procedure bug fixed
NEC/Renesas uPD78F0058, programming procedure bug fixed
NEC/Renesas uPD78F0893, communication error fixed
NEC/Renesas uPD78F9418A, programming procedure bug fixed
NEC/Renesas uPD78F9456, programming procedure bug fixed
NEC uPD78F0828B, programming procedure bug fixed
OKI MR27V32xx, insertion test fixed
Primarion and Elmos devices, default program action bug fixed
Renesas R5F10x, Insertion test procedure bug fixed for devices in LQFP44 supported with DIL48/LQFP44 ZIF R5F-1
Renesas R5F5631AxxFB, programming address bug fixed
Renesas/Mitsubishi QzROM Family, programming procedure bug fixed
STMicroelectronics M95128-R [MLP8], verification procedure bug fixed
STMicroelectronics STM8T143, blank check bug fixed
TI (TMS) LM3Sxxxx family, programming bug fixed
Xilinx XCF02S, communication error fixed
