Added module: AP1 QFN20-6.02 ZIF
Added module: AP1 QFN32-2.02 ZIF ISL-1
Added module: AP1 QFN40-1.02 ZIF UCD-2
Added module: AP1 QFN52-1.02 ZIF ISL-2
Added module: AP1 WQFN32 ZIF R5F-1
Module AP1 BGA24-2 ZIF SGlash-1b enabled as an alternative for serial NAND
Microchip ATtiny427 [QFN24], ATtiny827 [QFN24], ATtiny1627 [QFN24], added support
Renesas R5F100Bxx, R5F101Bxx, R5F104Bxx, R5F109Bxx, R5F10EBxx, R5F10JBxx, R5F10KBxx, R5F117Bxx, R85F11CBxx in WQFN32 package, added support
Renesas R5F117BAxNA [WQFN32], "Unexpected error 1 [IEC:1, D:5F]!" error when using AP1 WQFN32 ZIF R5F-1 fixed
New software - Version 3.70
Postby Dataman (Daniel Smith) » 14 Sep 2021 11:00
Users browsing this forum: Semrush [Bot] and 4 guests
