Added module: AP1 BGA100-5.01 ZIF STM32G4-1
Added module: AP1 BGA24-3 ZIF HFlash-1
Added module: AP1 QFP64-1.01 ZIF NUC-8
Added module: AP1 SOIC8 ZIF CY-2
Microchip PIC18F57Q43, PIC18F57Q83, PIC18F57Q84, added support
New software - Version 3.73
Postby Dataman (Daniel Smith) » 14 Jan 2022 16:13
