New software - Version 3.81
Postby Dataman (Daniel Smith) » 25 Nov 2022 16:23
Version 3.81 features the following amendments:
General Options/File Load, added functionality "Calculate checksum of file to be loaded before processing"
mDOC H3 devices, fixed PG4UW software exception "Access violation" bug if the image file is larger than 2GB
Writing of erase value of buffer block operations in log fixed
Added support for Infineon 8-bit F2MC New 8FX family CY95Fxxx devices (ex Cypress/Spansion)
Added support for Infineon FM3 32-bit Arm Cortex-M3 devices (ex Cypress/Spansion)
Added support for Infineon FM4 32-bit Arm Cortex-M4 devices (ex Cypress/Spansion)
Added support for Infineon FM0+ 32-bit Arm Cortex-M0+ devices (ex Cypress/Spansion)
Analog Devices ADUC7023xxxxx62I [LFCSP32], Added reading procedure
Atmel/Microchip AT89C5131, Setting Extra Row modified
Atmel/Microchip ATtiny406/806/1606 [VQFN20], added new programming adapter option
Atmel/Microchip ATtiny416/816/1616/3216 [VQFN20], added new programming adapter option
Cypress CY8C6 family, reliability of communication improved
GigaDevice GD25Q32C, GD25Q64C, setting Protected memory modified
Gowin Semicond. LittleBee family, pgm parameters assignment improved
Gowin Semicond. LittleBee family, added device versions
Gowin Semicond. LittleBee and Arora families, added binary file format support
Microchip ATtiny426/826/1626 [VQFN20], added new programming adapter option
Microchip dsPIC33CH256MP505, programming/verification procedure improved
Microchip dsPIC33CH256MP505, load hex file and FCFGPRB0 bits in the Alt+S menu improved
Microchip PIC24FJ128GB106, programming procedure for Configuration words improved
Microchip PIC32MZ EF Family, default adresses for configuration bits improved
NAND flash devices, "User Data with IB Info Forced" spare area usage mode supressed for OTP area (User Data mode used instead)
Renesas R5F566Txxxxx, buffer size modified
Renesas R5F5630DxxFB, device info modified
Renesas/Mitsubishi M30845FJGP, programming Boot ROM modified
STMicroelectronics STM32G0xx devices, algorithms modifified
STMicroelectronics STM32H723xx and STM32H733xx ISP devices blank check speed improvement
STMicroelectronics STM32L4 Series, programming method changed (introduced modes program all data, only data from file, only nonblank data; discarded mode program selected pages)
Winbond W25Q01JVxxxQ, default value DRV0, DRV1 bits of Status register changed
Winbond W25Q128JVxxM-DTR [SOIC8-200] (QuadSPI), verification procedure improved
XTX XT25F16B, added QE Bit programming
Atmel/Microchip AT90PWM316 [QFN32], device info corrected. Flash and EEPROM size and addresses corrected.
Motorola, Freescale MC908AS60, EENVRx programming bug fixed
Nuvoton W78E516D, Security register programming bug fixed
NXP PD692xx, communication timeout during PGM fixed
STMicroelectronics STM32G0x1 devices, FLASH_SECR bug fixed
TI (TMS) TPS53685, TPC536C5, insertion test bug fixed
TI (TMS) TPS53689, TPS536C9 - info about supported programming file bug fixed
Winbond W25N serial NAND, block protection check problem on Blank operation fixed
