New software - Version 3.85
Postby Dataman (Daniel Smith) » 04 May 2023 10:56
Micron M25P32-V [SO16], added support
Numonyx M25P32-V [SO16], added support
STMicroelectronics M25P32-V [SOIC16], added support
