Problem flashing Winbond 29C011A
Postby Guest » 10 Nov 2011 10:49
I have a motherboard BIOS chip, that need to be upgraded. However, I´m not able to flash the new data to the chip. I get an error message, with different values in ROM and RAM. I had a similar BIOS problem with a W29EE011 chip, but it programs ok. However, the motherboard does not accept that chip for some reason.
GGeorgss
Re: Problem flashing Winbond 29C011A
Just adding that I have a S4 programmer with 512K RAM and latest library.
GGeorgss
Postby Dataman (Neil Parker) » 10 Nov 2011 10:50
It sounds as though the chip you are trying to program is not blank or is damaged. Try doing an erase on the device using FUNC > BURN.
If you still experience problems please contact us.
Reagrds,
Postby Guest » 10 Nov 2011 10:50
Thanks for the answer. However, it does not work to erase the chip that way. I get an error message. So it looks like the chip is fried. ;-)
GGeorgss
