New software - Version 3.87
Postby Dataman (Daniel Smith) » 08 Sep 2023 10:59
Version 3.87 features the following amendments:
Added adapter: BGA-Bottom-558
Added adapter: DIL48/BGA121-4 ZIF CY-3
Added adapter: DIL48/BGA180-1 ZIF-CS PLD-1
Added adapter: DIL48/QFN24-1.02 ZIF AUO-1
Added adapter: DIL48/QFN36-2.02 ZIF PIC-2
Added adapter: DIL48/QFN36-2.02 ZIF PIC-3
Added adapter: DIL48/QFN48-1.02 ZIF R7FA-1
Added adapter: DIL48/QFN48-2.02 ZIF AT32-1
Added adapter: DIL48/QFN56-1.02 ZIF PTN-1
Added adapter: DIL48/QFN60-1.02 ZIF ISL-2
Added adapter: DIL48/QFN73 ZIF RAK1
Added adapter: DIL48/QFP100-1.02 ZIF AT32-1
Added adapter: DIL48/QFP176-1.02 ZIF R7F-3
Added adapter: DIL48/QFP64-1.02 ZIF AT32-1
Added adapter: DIL48/QFP80-1.02 ZIF R7FA-1
Added adapter: DIL48/SO8-EP ZIF Elmos-1
Added adapter: DIL48/SOIC14-150 ZIF ISD-1
Added adapter: DIL48/TSSOP20-170 ZIF MM32-1
Added adapter: DIL48/TSSOP28-170 ZIF M03x-1
Altera EPC1/1444, adding device info with decoupling capacitor
Atmel/Microchip ATmega32U4, Fuse bits warning message removed and device info modified
Atmel/Microchip ATmega32U4, View/edit Fuses, Lock and Calibration bytes window modified
Atmel/Microchip ATSAMD21G17D, added RWW-flash area support
ARTERY AT32F421, added support for Flash memory extension area erase/program protection, Security library support improved (old/new password), devices partname extended (operating temperature identifier added due to strict device IDs)
Azoteq IQS211B [DFN6], IQS227D [DFN6], verification procedure improved
Cypress CYT2B94CACQ0AZSGS [LQFP80], read/program/verify algorithm modified
Cypress CY7C27x, programming algorithm modified
Cypress/Infineon CY91F213APMC [LQFP144], verify procedure improved
DIL48/DRQFN44 ZIF AVR-1, Automatic yes parameters modified
Espressif ESP32-WROVER-E-N8Rx, programming procedure improved
Freescale Semic. MC9S12Bxxx, algorithm stability improvement
Freescale Semic., NXP MC9S12Xxxx (ISP), added VDD reconnect during Erase procedure
Freescale Semic., NXP MWCT2013, supported programmers restriction removed
Freescale Semic. S908QY4 (ISP all-wire)(EPS-01), added support, restricted for certain programmers
GigaDevice GD5F2GQ5UEYIG [WSON8] (64B spare), Winbond W25N02KVZE [WSON8] (64B spare), the setting of internal ECC controller is made available
Hitachi HD64F3334YF, HD64F3337YF, support modified
Infineon XMC4xxx, programming algorithm improved
Intel DT28F160S3 [SSOP56], power-up procedure modified
ITE Tech. Inc. IT6563FN, erase procedure and power-up procedure modified
Microchip/Microsemi DirectC devices, update of DirectC player to v2022.1
Microchip PIC24FJ256GB106, verification procedure improved
Microchip PIC24FJ256GB106, programming procedure for Configuration words improved
Micron MTFC128GBCAQTC [LFBGA153], programming DELAY_1, DELAY_2, SELF_REFRESH algorithm modified
Micron MTFC128GBCAQTC [LFBGA153], programming PRODUCT_STATE_AWARENESS_ENABLEMENT[17] modified
Nordic nRF52xx, modified save DEVICEID and DEVICEADDR to CSV file
Nordic nRF9160-SICA-B1A [LGA127] (modem), timeout for operation result modified
Nuvoton ISD21xx, power-off procedure and read/verify operations improved
NXP LPC1225/301 [LQFP48], programming procedure improved
NXP LPC1xxx, LPC2xxx, LPC4xxx, programming procedure speed-up
NXP LPC546xx, erase procedure improved
Nyquest Technology N25Q Series, read operations improved
Realtek RTL8721DFL, alternative device ID code added
Renesas R5F564MLxxLK, option to set value of Endian select register added
Renesas/Intersil ISL69239, power-up procedure improved
Samsung KLMBG2JETD-B041 [FBGA153], added support PRV 0.9
STMicroelectronics SPC58xBxxE3, added support for UTEST and BAF memory block
TI (TMS) CC2530F256 [QFN40], programming procedure improved
TI (TMS) LMK03328 [WQFN48], programming algorithm modification
TI (TMS) LMK05318 [VQFN48], improving of a EPR file loading
TI (TMS) MSPM0Lx devices, Device info updated
TI (TMS) TPS53622, TPS53622A, PMBus Programmer Script file processing improved
Winbond W25Q16JVxxxQ [SOIC8-150], added adapter DIL8W/SOIC8 ZIF 150mil SFlash-1b
Winbond W25Q256JVxxN, configuration bit ADP added
Winbond W25Q64JVxxxM [WSON8 6x5], added adapter DIL8/QFN8-1 ZIF SFlash-1b
Winbond W25R256JVxxQ, Alt+S menu improved
Winbond W25R256JVxxQ [WSON8 8x6](QuadSPI)(+RPMC), programming procedure improved
ABOV Semiconductor MC97F2464A [LQFP44], Unexpected error 1 [IEC:2, D:02]! bug fixed
Adapter DIL48/BGA416-1 ZIF xPC55-1 (discontinued), identification problem bug fixed
Atmel/Microchip AVR XMEGA family, "Communication with device fail. Error code: 00000099" bug fixed
Atmel/Microchip AVR8 (ISP-JTAG), progressbar bug fixed
ARTERY AT32F421, User System Data area blank check fixed (permanent blank check error was reported)
DIL48/WLCSP30-2 ZIF PLD-1, adapter name bug fixed
Dosilicon DSND4G08U3C [TSOP48], fixed Device info/Package details
Espressif ESP32-WROOM, ESP32-WROVER series, read eFUSE area bug fixed
Espressif ESP32-WROVER-E-N8Rx, "Out of memory" bug fixed
Espressif ESP32-WROVER-E-N8Rx, intermittent "Uploading bootloader - error!" bug fixed
Espressif ESP32-WROVER-E-N8Rx, "Communication error PC-programmer!" during read operation bug fixed
Lattice iCE40, programming bug fixed (Access with selected device - error!, error codes: GE: 240, HE: 0)
Lattice MachXO3, caBGA256, 1.2V devices, power supply bug fixed
Microchip 24LC41, 24LC41A, 24LCS41, 24LCS41A, programming bug fixed
Microchip dsPIC33CK256MP505, erase procedure bug fixed
Microchip PIC16F18xxx (ISP), power-on in LVP mode bug fixed
NEC/Renesas uPD70F3633, Communication problem fixed
Nuvoton M058SFAN [TSSOP20], programming Data Flash bug fixed
NXP LPC134x, programming "Code read protection (CRP)" bug fixed
NXP MK20DX256xxx10 [LQFP100], 'Unexpected error 1 [IEC:1, D:1A]!' bug fixed
NXP/Freescale Semic. MK60FN1M0, 'Unexpected error 1 IEC:1, D:0F' bug fixed
Realtek RTL8721DF [QFN56], incorrect size of device fixed
Sandisk SDIN4C2-xxG, insertion test bug fixed
STMicroelectronics STM32H7Ax, verify algorithm bug fixed
STMicroelectronics STM32U5xx, option bytes modified, read/verify when security enabled algorithm bug fixed
Texas Instruments MSPM0L1105 [VSSOP20], MSPM0L1305 [QFN32], Flash size bug fixed
TI (TMS) CC2652P74T0, device info corrected, incorrect size of device fixed
TI (TMS) CC2652P74T0, programming bug fixed
