New software - Version 4.01
Postby Dataman (Daniel Smith) » 21 Mar 2025 14:37
Version 4.01 features the following amendments:
Windows 10/11 USB driver: "Install class is not present or is invalid" bug fixed
Added adapter: BGA-Top-402a ZIF
Added adapter: DIL48/module ZIF Dialog-1
Added adapter: DIL48/QFN32-1.02 ZIF NEC-1
Added adapter: DIL48/QFN56-1.02 ZIF MAX-3
Added adapter: DIL48/QFP64-1.02 ZIF STM32U-2
Added adapter: DIL48/QFP80-1.02 ZIF R5F-7
Anlogic EF3L40xxxxxB [caBGA324](SVF), improving of power sequence
Atmel/Microchip ATtinyxx06/xx16/xx26 [VQFN20], insertion test modified
cFeon(Eon Si.Sol.) EN25SX64A(2U) [WSON8 6x5] (QuadSPI), changed device name and backward project compatibility
Cypress CY27410F, programming procedure improvement
Dallas/Maxim DS2432, Load first secret skipped if write protected and EEPROM programming is selected
DIL48/QFN46-1.01 ZIF-CS RTL-1, Automatic Yes! parameters modified
DIL48/QFN32-2.02 ZIF EFR-2, interface update
Discontinued adapter BGA-Top-402 ZIF, replaced by BGA-Top-402a ZIF
Eon Silicon Sol. EN25SX64A(2U) [WSON8 6x5] (QuadSPI), changed device name and backward project compatibility
ESMT EN25SX64A(2U) [WSON8 6x5] (QuadSPI), changed device name and backward project compatibility
ESMT FC51L04SFSA-2.5BWGE2A [FBGA153], power-up procedure improved
Lattice LC4064V [TQFP44], improving of power sequence
Microchip AVR EB, DD, DU family in VQFN20 package, insertion test modified
Microchip PIC16F/LF1828/1829 in SSOP20, communication problem improved
Microchip PIC24FJ64GA006, added IESO configuration bit
Microchip PIC32MZ2048EFM144 in 2wire JTAG mode, programming of configuration bits improved
Micron MT25QL128ABB1Exx-C, changed device name and backward project compatibility
ON Semiconductor LE25U40C [SOP8], changed device name and backward project compatibility
Puya Semiconductor P25Q16SH, ID check procedure improved
Renesas R5F10NMJxFB, R5F10NPJxFB, verification procedure improved
Renesas R5F5631xxxxx, programming Security bit modified
STMicroelectronics PSD family, reduced communication speed for ISP
STMicroelectronics STM32U5 series, programming method changed (introduced modes program all data, only data from file, only nonblank data; discarded mode program selected pages); Option bytes erase algorithm modified
Telink TLSR8208H, verifying procedure speed-up
Adapter DIL48/QFP120-1.02 ZIF-CS A34-1, adapter test - error! fixed
GigaDevice GD32F425, GD32F427 and GD32F470, file load/save procedures fixed for OTP area data
HeYangTek HYF1GQ4IDACAE [WSON8], HYF1GQ4IDACAE [LCC8 type 1], HYF1GQ4IDACAE [LCC8 type 2], HYF1GQ4UDACAE [WSON8], HYF1GQ4UHCCAE [LGA8L], HYF2GQ4UDACAE [WSON8], HYF2GQ4UDDCAE [TFBGA24], buffer size fixed
Macronix MX25V1606F, device info corrected, incorrect size of device fixed
Microchip PIC16F628A (ISP-ext.VDD), Unexpected error 1 [IEC:1, D:3D]! bug fixed
Microchip PIC32MX575F256L [TQFP100 12x12](2wire JTAG), PIC32MX575F256L [TQFP100 14x14](2wire JTAG), communication problem fixed
Micron MT29F8G08ADAFAWP-AAT [TSOP48] (EPS-22), buffer size fixed
Renesas/Intersil RAA229134, verification bug fixed
STMicroelectronics STM32H503, SWJDP communication problem fixed
