The programmer is unable to read or check the blank device (two different devices). I am getting the "Device overcurrent error".
I get the same error when I tried to program.
Please, I desperately need help. I would be very glad, if someone could assist me in resolving this issue.
Thank you very much.
Simeon.
W25Q128FV Device Overcurrent Error
Re: W25Q128FV Device Overcurrent Error
Hello Simeon,
Which Dataman programmer model do you have? Which package is your chip in and which adaptor socket do you have?
Usually a device overcurrent error indicates a short to ground, which would indicate an internally damaged or destroyed chip.
Dpending on the programmer model that you have it is possible to run a selftest on the programmer to check the programmers internal hardware and rule this out as the cause of this situation.
Simeon Ade
Thank you very much for your quick response. Below are the requested information:
Programmer model: Dataman-48PRO2
Chip package: SOIC8
Adaptor Socket: 48 pins to fit in zif socket and a 16 in (top) socket
I do not know how to run self-test. Can you please advise how to do that.
Looking forward to your urgent response. Thank you very much.
Simeon.
Chip package: SOIC8
Simeon.
Hello Simeon,
Thank you for the informaiton. The xx device in SOIC8 200mil package is supported on the D48Pro2 as:
Device info:
Manufacturer: Winbond
Partname: W25Q128FV [SOIC8-200] (QuadSPI)
8-bit bytes: 1000300h (16,777,984 Bytes)
Organization: 1000300h (x8 bit)
Algorithm: Quad I/O SPI
Implemented in SW ver. (summary): 2.97 or earlier
Modified in SW ver. (summary): 3.58f
Implemented in SW ver. (Dataman-48Pro2): 2.97 or earlier
Modified in SW ver. (Dataman-48Pro2): 3.58f
Package Info: SOIC(8) 208mil
Supported by programmers and programming adapters/modules:
Dataman-48Pro2 with adapter/module:
DIL8W/SOIC8 ZIF 200mil SFlash-1b or
DIL8W/SOIC8 ZIF 200mil SFlash-1a
Please confirm that you have one of the two adaptor sockets listed above. Any other type of adaptor socket will not work and may be the reason for this device overcurrent situation.
For future reference, there is an adaptor selection guide on our website here: https://uk.dataman.com/adapters/adapter ... ide-1.html
The selftest of the programmer can be performed by selecting "Selftest..." from the programmer menu using the supplied 48pin diagnostic pod and following the instructions. Please let me know the result.
Device info:
Simeon Ade
Good morning Neil,
Thank you very much for your assistance.
I used the programing setup you suggested, but the overcurrent error is still not resolved. I tested additional five ICs (devices), the same error persisted in them.
I am also using the correct Dataman-48Pro2 adapter/module: DIL8W/SOIC8 ZIF 200mil SFlash-1a
Regarding performing self-test, I cannot carry it out as I can no longer find the 48pin diagnostic pod.
Please, if there is any further assistance you can offer, I will greatly appreciate it. Looking forward to your response.
Simeon.
Simeon.
Hello Simeon,
We really need to know the results of the selftest procedure to rule out the programmer hardware as a potential cause.
Replacements diagnostic PODs can be purchased through our website: 48-Pin Diagnostic POD
Once received, please run the Selftest procedure (Programmer > Selftest…) with and without the diagnostic POD when instructed. After this has completed, please generate a problem report (Help > Create problem report) and email [email protected] the resulting ZIP file for analysis.
