SST39SF040A-70-4C-NH not supportet?
Postby Guest » 10 Nov 2011 10:59
Hello!
I can't program this device with S4 and the 8-Bit Flash/Eprom Library V1.11. The Signature of this Chip is: A35F
If there an possibility to program this flash? (Compatible programming algorithm flash-types?)
Thanks in advance
Diethard
Re: SST39SF040A-70-4C-NH not supportet?
Postby Dataman (Neil Parker) » 10 Nov 2011 10:59
Diethard
I cannot find the "A" devices on the SST website. Where did you buy them from?
Do you have a datasheet for the parts?
I need more information.
Hello Neil!
I didn't have a datasheet.
I have found a Link :
http://www.chipdocs.com/pndecoder/datas ... ?ReR=%20GG
But datasheets downloading from ChipDocs is only for members.
Sorry but my Flash didn't have this 'a' extension!
That was a big mistake by me!
(i was sitting i my company without having the flash by hand but i knew most of the partname, so i gooogled them and posted this devicename!)
Thanks Diethard
Postby Dataman (Neil Parker) » 10 Nov 2011 11:00
You can select SST 39SF040 manually. The ID you read from S4 is not correct.
S4 does not support so-called software ID.
First erase by FUNC BURN, then check by TEST to see if it is blank.
Then BURN.
It works here.
Postby Guest » 10 Nov 2011 11:00
i tried that and it just says "sorry,impossible"
