New software - Version 2.59
Postby Dataman (Daniel Smith) » 27 Nov 2011 12:52
Version 2.59 features the following amendments:
Atmel AT28LV010 programming bug fixed
Atmel AT90PWM3 series, verify bug fixed
Microchip dsPIC30F601xA, insertion test bug fixed
Philips/Signetics N82HS321, programming bug fixed
Winbond W27C512, W27E512, Blank Check algorithm bug fixed
Ramtron FM25CL64, programming procedure bug fixed
Intel/Numonyx TE28F320J3D, programming bug fixed
STMicroelectronics ST72F321R9T [TQFP64], option bytes programming bug fixed
Sharp LH28F800BJHG-PBTL [CSP48], bug in erase procedure fixed
Atmel AT90PWM3 [QFN32], insertion test bug fixed
Texas Instruments BQ2022ADBZR [SOT23], read and program procedure bug fixed
Atmel AT91FR40162S [FBGA121], programming and erase procedure bug fixed
Microchip PIC24HJxxx (ISP), power-up procedure bug fixed
Microchip PIC18FxxKxx, verification procedure bug fixed
Intel PF38F5060M0Y3DF [SCSP56], communication error fixed
Atmel AT90CAN32, Boot size settings fixed
Atmel ATtiny167 [qfn32], pinout bug fixed
Freescale/Motorola MC9S08GT60, algorithm instability bug fixed
Fixed bug for identifying BGA-Bottom-192 DPS in BGA socket converters, related to devices
STM/Numonyx M58LT128xxxxxx and M58LT256xxxxxx
AMD Am29DL640G, erase procedure modified
Atmel AT91SAM7S32 [LQFP48] (FLEX-1), improving of insertion test
Atmel AT89C51RD2-xM (ISP), HSB byte programming improved
ICT PEEL18CV8, changing of overcurrent protection parameters
AMD/Lattice/Vantis PALCE20RA10H, changing of overcurrent protection parameters, increasing of verification and reading stability
AMD/Lattice/Vantis PALCE16V8Z, adding of ID code
Eon EN29LV800CB [TSOP48], programming algorithm improved
Eon EN29PL064 [TSOP48], ID check procedure improved
Philips/NXP LPC2378 [LQFP144], improving of programming procedure
Philips/NXP P89LPC9xx, default setting UCFG2 set to value 00h
Infineon XC886/888, programming speed increased
TI (TMS) MSP430F2001/2002/2003/2011/2012/2013 in ZIF, Information memory and Main memory can be programmed separately
Xilinx XC9500/XL/XV, algorithm improving, increasing of programming and verification stability
Numonyx M29W128GH/L, Password Protection mode programming modified
Numonyx M29W320E, special power-up during converter identification added
Nuvoton/Winbond W83L951 [LQFP128], improving of programming procedure
Chipcon/TI CC2510 [QLP36], improving of insertion test
Philips/NXP, all UOC Fighter, load DMP files procedure improved
MemoCom KI03208AB [TFBGA58], improving of device pin assignment
NEC uPD27C64 programming algorithm improvement
STMicroelectronics STM8 family in ISP mode, programming speed increased
Atmel AT89C51CC01-xM (ISP) and AT89C51CC03-xM (ISP), programming and erase procedure modified
Atmel AT90CAN32, displaying of verify results improved
Atmel AT32UC3B0256 [QFN64], program and erase functions improved
Atmel AVR-8 series, AVR-32 series, identification of errors improved
Philips/NXP TDA11116H/N2 [QFP80], improving of entering pgm. mode
Philips/NXP TDA12156H1/N3 [QFP80], improving of entering pgm. mode
Microchip PIC18F6722, display of User IDs improved
Microchip PIC18Fxxxx Family, display of User IDs improved
Spansion S25FL032P (QuadSPI), S25FL064P (QuadSPI), programming speed increased
STMicroelectronics STM8AF51AAT (ISP), erase procedure modified, programming reliability improved
Lattice ispMACH4000, ispMACH5000VG/5000B, ispGDX2, ispGAL22V10A, ispXPLD5000MX, LA-ispMACH4000, ispMACH4000ZE, improving of pgm. algorithm according to the latest pgm. specification
Micron's NAND flash devices in BGA packages, selection based on BGA code allowed
user algorithm AML-01 modification, programming speed improvement, added invalid blocks erasing to 00h
User algorithm BSP-01 modification, table constants changed upon user request
Customers algorithms QIS-01 and QIS-02 modification
BGA-Top-207 ZIF, improving of converter name
DIL48/QFP144 ZIF PLD-7, improving of pgm. parameters assignment
DIL48/QFP64-1 ZIF HCS08-1 socket converter, interface improvement
DIL48/QFP52 ZIF PSD-1 socket converter, identification improvement
