*Macronix MX25V512F [UDFN8 2x3], added adapter DIL8/QFN8-4 ZIF-CS SFlash-1
ITE IT8110E, erase bug fixed
New software - Version 3.28
Postby Dataman (Daniel Smith) » 13 Dec 2016 15:56
