Added support of AP1 BGA-1122/1121 module
JEDEC file load bug fixed
Microchip PIC16F1933 [UQFN28], Insertion test bug fixed
Microchip PIC18FxxJxx [TQFP44], insertion test bug fixed
New software - Version 3.29
Postby Dataman (Daniel Smith) » 26 Jan 2017 17:20
