New software - Version 3.31
Postby Dataman (Daniel Smith) » 04 Apr 2017 13:31
Added support of AP1 BGA64-2.1 NOR-4 module
Added support of AP1 QFP100 ZIF MSP430-3 module
Added support of AP1 SSOP10 ZIF 120mil module
Added support of AP1 SSOP30 ZIF 240mil module
Added support of AP1 VQFN132 ZIF MV250 module
