Help
cyoung
Help
Postby cyoung » 24 Feb 2012 20:56
Hi, I've been trying to programme several different 89S52 (Atmel) to no avail. It programmes okay but when it's placed in the circuit nothing happens- I'm almost certain circuit + code okay. I put mcu back into dataman to verify and the following error report was returned to me:
Any help appreciated! 'Sorry 'bout this extended post'
**************** New report. Created: 24.02.2012 19:30:08*****************
Welcome to Dataman programmers control program PG4UW.
L0002: Version 2.86/01.2012.
L0003:
L0004: Today is 24.02.2012, 19:30:08.
L0005:
L0006: Processor: Intel (6/5/5) Frequency: 2394\2394.38 MHz
L0007: CID: C43B-DBE9:4C-0F-6E-DF-16-1B::043F3CFB
L0008: Operating system: Windows 7 x64 (v6.1, Build 7600).
L0009: Physical RAM memory: 3758 MB or more.
L0010: Selected language: English
L0011:
L0012:
L0013: >> 24.02.2012, 19:30:09
L0014: Default programmer: None, scan for any.
L0015:
L0016: >> 24.02.2012, 19:30:26
L0017:
L0018: >> 24.02.2012, 19:30:26
L0019: Scanning port(s) for Dataman-40Pro .............. found at port USB.
L0020: Establishing connection ... done.
L0021: Communication speed rate: reached 100% of maximum in this communication mode.
L0022: Programmer serial number: 233-05963.
L0023:
L0024:
L0025:
L0026: >> 24.02.2012, 19:30:28
L0027: Buffer checksum type is set to "Byte sum (x8)"
L0028: Exclude buffer data for checksum: Disabled
L0029:
L0030: >> Log file created at 24.02.2012 19:30:28
L0031: Log file name: C:\Users\Cian\AppData\Roaming\Dataman\Dataman-Pro\report.rep
L0032: Log file mode: Append
L0033:
L0034: >> 24.02.2012, 19:32:24
L0035: Selected device (by Select): Atmel AT89S52.
L0036: Buffer checksum in range of [0h..1FFFh]: 001FE000h - Byte sum (x8)
L0037: --------------------------
L0038: Device operation options:
L0039: --------------------------
L0040: - Addresses
L0041: Device start: 0000000000
L0042: Device end: 0000001FFF
L0043: Buffer start: 0000000000
L0044: Split: None
L0045: - Insertion test and/or ID check
L0046: Insertion test: Enable
L0047: Device ID check error terminates the operation: Enable
L0048: - Command execution
L0049: Erase before programming: Disable
L0050: Blank check before programming: Disable
L0051: Verify after reading: Enable
L0052: Verify: Once
L0053: Verify options: Not supported
L0054: - Programming parameters
L0055: [ ] Flash
L0056: [ ] Lock bits
L0057: ---------------------
L0058: View/Edit lock bits:
L0059: ---------------------
L0060: [ ] Lock bit 1
L0061: [ ] Lock bit 2
L0062: [ ] Lock bit 3
L0063: ---- End of options list ----
L0064:
L0065: Selected device: Atmel AT89S52.
L0066: Buffer checksum in range of [0h..1FFFh]: 001FE000h - Byte sum (x8)
L0067:
L0068: >> 24.02.2012, 19:32:35
L0069: Verifying device: Atmel AT89S52.
L0070: Buffer checksum in range of [0h..1FFFh]: 001FE000h - Byte sum (x8)
L0071: Device insertion test ...
L0072: Checking device ID ...
L0073: Verifying device with buffer ...
L0074: Verifying device - error!
L0075:
L0076: Verify - error(s)
L0077:
L0078: ADDRESS DEVICE BUFFER | ADDRESS DEVICE BUFFER | ADDRESS DEVICE BUFFER
L0079: ------------------------|-------------------------|------------------------
L0080: 00000000 02 FF | 0000080C FA FF | 0000081B 01 FF
L0081: 00000001 08 FF | 0000080D 0B FF | 0000081C 0C FF
L0082: 00000002 3B FF | 0000080E BB FF | 0000081D 80 FF
L0083: 00000800 E4 FF | 0000080F 00 FF | 0000081E E4 FF
L0084: 00000801 FD FF | 00000810 01 FF | 0000081F 22 FF
L0085: 00000802 FC FF | 00000811 0A FF | 00000820 75 FF
L0086: 00000803 C3 FF | 00000812 BA FF | 00000821 90 FF
L0087: 00000804 ED FF | 00000813 01 FF | 00000823 D2 FF
L0088: 00000805 9F FF | 00000814 F8 FF | 00000824 A0 FF
L0089: 00000806 EC FF | 00000815 BB FF | 00000825 7F FF
L0090: 00000807 9E FF | 00000816 F4 FF | 00000826 C8 FF
L0091: 00000808 50 FF | 00000817 F5 FF | 00000827 7E FF
L0092: 00000809 15 FF | 00000818 0D FF | 00000828 00 FF
L0093: 0000080A E4 FF | 00000819 BD FF | 00000829 12 FF
L0094: 0000080B FB FF | 0000081A 00 FF | 0000082A 08 FF
L0095:
L0096: Elapsed time: 0:00:03.0
L0097: Statistics info: Success:0 Failure:1 Other failure:0 Total:1
L0098:
L0099: >> 24.02.2012, 19:32:56
L0100: Erasing device: Atmel AT89S52.
L0101: Device insertion test ...
L0102: Erasing device ...
L0103: Chip erase verify by Blank check procedure ...
L0104: Erasing device - O.K.
L0105: Elapsed time: 0:00:03.3
L0106: Statistics info: Success:1 Failure:1 Other failure:0 Total:2
L0107:
L0108: >> 24.02.2012, 19:33:26
L0109: Loading file (from "Load file" dialog window): C:\Users\Cian\Desktop\Fri\Will_it.hex
L0110: File format selection: automatic
L0111: File format: IntelHEX
L0112: Negative offset (manual): 00000000h
L0113: Range of addresses: 0h - 84Ah
L0114: File loading successful.
L0115: Buffer checksum in range of [0h..1FFFh]: 001FB9D7h - Byte sum (x8)
L0116:
L0117: >> 24.02.2012, 19:33:31
L0118: Verifying device: Atmel AT89S52.
L0119: Buffer checksum in range of [0h..1FFFh]: 001FB9D7h - Byte sum (x8)
L0120: Device insertion test ...
L0121: Checking device ID ...
L0122: Verifying device with buffer ...
L0123: Verifying device - error!
L0124:
L0125: Verify - error(s)
L0126:
L0127: ADDRESS DEVICE BUFFER | ADDRESS DEVICE BUFFER | ADDRESS DEVICE BUFFER
L0128: ------------------------|-------------------------|------------------------
L0129: 00000000 FF 02 | 0000080C FF FA | 0000081B FF 01
L0130: 00000001 FF 08 | 0000080D FF 0B | 0000081C FF 0C
L0131: 00000002 FF 3F | 0000080E FF BB | 0000081D FF 80
L0132: 00000800 FF E4 | 0000080F FF 00 | 0000081E FF E4
L0133: 00000801 FF FD | 00000810 FF 01 | 0000081F FF 22
L0134: 00000802 FF FC | 00000811 FF 0A | 00000820 FF 75
L0135: 00000803 FF C3 | 00000812 FF BA | 00000821 FF 90
L0136: 00000804 FF ED | 00000813 FF 01 | 00000823 FF D2
L0137: 00000805 FF 9F | 00000814 FF F8 | 00000824 FF B0
L0138: 00000806 FF EC | 00000815 FF BB | 00000825 FF D2
L0139: 00000807 FF 9E | 00000816 FF F4 | 00000826 FF B7
L0140: 00000808 FF 50 | 00000817 FF F5 | 00000827 FF D2
L0141: 00000809 FF 15 | 00000818 FF 0D | 00000828 FF A0
L0142: 0000080A FF E4 | 00000819 FF BD | 00000829 FF 7F
L0143: 0000080B FF FB | 0000081A FF 00 | 0000082A FF C8
L0144:
L0145: Elapsed time: 0:00:03.0
L0146: Statistics info: Success:1 Failure:2 Other failure:0 Total:3
L0147:
L0148: >> 24.02.2012, 19:33:43
L0149: Erasing device: Atmel AT89S52.
L0150: Device insertion test ...
L0151: Erasing device ...
L0152: Chip erase verify by Blank check procedure ...
L0153: Erasing device - O.K.
L0154: Elapsed time: 0:00:03.3
L0155: Statistics info: Success:2 Failure:2 Other failure:0 Total:4
L0156:
L0157: >> 24.02.2012, 19:34:10
L0158: --------------------------
L0159: Device operation options:
L0160: --------------------------
L0161: - Addresses
L0162: Device start: 0000000000
L0163: Device end: 0000001FFF
L0164: Buffer start: 0000000000
L0165: Split: None
L0166: - Insertion test and/or ID check
L0167: Insertion test: Enable
L0168: Device ID check error terminates the operation: Enable
L0169: - Command execution
L0170: Erase before programming: Disable
L0171: Blank check before programming: Disable
L0172: Verify after reading: Enable
L0173: Verify: Once
L0174: Verify options: Not supported
L0175: - Programming parameters
L0176: [x] Flash
L0177: [ ] Lock bits
L0178:
L0179: >> 24.02.2012, 19:34:12
L0180: Programming device: Atmel AT89S52.
L0181: Buffer checksum in range of [0h..1FFFh]: 001FB9D7h - Byte sum (x8)
L0182: Device insertion test ...
L0183: Checking device ID ...
L0184: Programming device ...
L0185: Verifying device with buffer ...
L0186: Programming device - O.K.
L0187: Elapsed time: 0:00:03.0
L0188: Statistics info: Success:3 Failure:2 Other failure:0 Total:5
L0189:
L0190: >> 24.02.2012, 19:34:37
L0191: Verifying device: Atmel AT89S52.
L0192: Buffer checksum in range of [0h..1FFFh]: 001FB9D7h - Byte sum (x8)
L0193: Device insertion test ...
L0194: Checking device ID ...
L0195: Verifying device with buffer ...
L0196: Verifying device - O.K.
L0197: Elapsed time: 0:00:02.6
L0198: Statistics info: Success:4 Failure:2 Other failure:0 Total:6
L0199:
L0200: >> 24.02.2012, 19:34:49
L0201: Called reset statistics counter menu, confirmed by user.
L0202:
L0203: >> 24.02.2012, 19:34:49
L0204: Statistics counters were cleared to zero by user.
L0205:
L0206: >> 24.02.2012, 19:34:52
L0207: Erasing device: Atmel AT89S52.
L0208: Device insertion test ...
L0209: Erasing device ...
L0210: Chip erase verify by Blank check procedure ...
L0211: Erasing device - O.K.
L0212: Elapsed time: 0:00:03.3
L0213: Statistics info: Success:1 Failure:0 Other failure:0 Total:1
L0214:
L0215: >> 24.02.2012, 19:35:10
L0216: Loading file (from "Load file" dialog window): C:\Users\Cian\Desktop\Fri\Will_it.hex
L0217: File format selection: automatic
L0218: File format: IntelHEX
L0219: Negative offset (manual): 00000000h
L0220: Range of addresses: 0h - 84Ah
L0221: File loading successful.
L0222: Buffer checksum in range of [0h..1FFFh]: 001FB9D7h - Byte sum (x8)
L0223:
L0224: >> 24.02.2012, 19:35:24
L0225: --------------------------
L0226: Device operation options:
L0227: --------------------------
L0228: - Addresses
L0229: Device start: 0000000000
L0230: Device end: 0000001FFF
L0231: Buffer start: 0000000000
L0232: Split: None
L0233: - Insertion test and/or ID check
L0234: Insertion test: Enable
L0235: Device ID check error terminates the operation: Enable
L0236: - Command execution
L0237: Erase before programming: Disable
L0238: Blank check before programming: Disable
L0239: Verify after reading: Enable
L0240: Verify: Once
L0241: Verify options: Not supported
L0242: - Programming parameters
L0243: [x] Flash
L0244: [ ] Lock bits
L0245:
L0246: >> 24.02.2012, 19:35:29
L0247: Programming device: Atmel AT89S52.
L0248: Buffer checksum in range of [0h..1FFFh]: 001FB9D7h - Byte sum (x8)
L0249: Device insertion test ...
L0250: Checking device ID ...
L0251: Programming device ...
L0252: Verifying device with buffer ...
L0253: Programming device - O.K.
L0254: Elapsed time: 0:00:02.9
L0255: Statistics info: Success:2 Failure:0 Other failure:0 Total:2
L0256:
L0257: >> 24.02.2012, 19:35:37
L0258: Verifying device: Atmel AT89S52.
L0259: Buffer checksum in range of [0h..1FFFh]: 001FB9D7h - Byte sum (x8)
L0260: Device insertion test ...
L0261: Checking device ID ...
L0262: Verifying device with buffer ...
L0263: Verifying device - O.K.
L0264: Elapsed time: 0:00:02.6
L0265: Statistics info: Success:3 Failure:0 Other failure:0 Total:3
L0266:
L0267: >> 24.02.2012, 19:35:58
L0268: Verifying device: Atmel AT89S52.
L0269: Buffer checksum in range of [0h..1FFFh]: 001FB9D7h - Byte sum (x8)
L0270: Device insertion test ...
L0271: Checking device ID ...
L0272: Verifying device with buffer ...
L0273: Verifying device - O.K.
L0274: Elapsed time: 0:00:02.6
L0275: Statistics info: Success:4 Failure:0 Other failure:0 Total:4
L0276:
L0277: >> 24.02.2012, 19:36:30
L0278: Reading device: Atmel AT89S52.
L0279: Device insertion test ...
L0280: Checking device ID ...
L0281: Reading device ...
L0282: Verifying device with buffer ...
L0283: Reading device - done.
L0284: Elapsed time: 0:00:04.3
L0285: Buffer checksum in range of [0h..1FFFh]: 001FB9D7h - Byte sum (x8)
L0286: Statistics info: Success:5 Failure:0 Other failure:0 Total:5
L0287:
L0288: >> 24.02.2012, 19:36:42
L0289: Verifying device: Atmel AT89S52.
L0290: Buffer checksum in range of [0h..1FFFh]: 001FB9D7h - Byte sum (x8)
L0291: Device insertion test ...
L0292: Checking device ID ...
L0293: Verifying device with buffer ...
L0294: Verifying device - O.K.
L0295: Elapsed time: 0:00:02.6
L0296: Statistics info: Success:6 Failure:0 Other failure:0 Total:6
L0297:
L0298: >> 24.02.2012, 19:37:14
L0299: Verifying device: Atmel AT89S52.
L0300: Buffer checksum in range of [0h..1FFFh]: 001FB9D7h - Byte sum (x8)
L0301: Device insertion test ...
L0302: Checking device ID ...
L0303: Verifying device with buffer ...
L0304: Verifying device - O.K.
L0305: Elapsed time: 0:00:02.6
L0306: Statistics info: Success:7 Failure:0 Other failure:0 Total:7
L0307:
L0308: >> 24.02.2012, 20:38:32
L0309: Erasing device: Atmel AT89S52.
L0310: Device insertion test ...
L0311: Erasing device ...
L0312: Chip erase verify by Blank check procedure ...
L0313: Erasing device - O.K.
L0314: Elapsed time: 0:00:03.3
L0315: Statistics info: Success:8 Failure:0 Other failure:0 Total:8
L0316:
L0317: >> 24.02.2012, 20:39:00
L0318: Loading file (from recently selected files): C:\Users\Cian\Desktop\Fri\Will_it.hex
L0319: File format: IntelHEX
L0320: Negative offset (manual): 00000000h
L0321: Range of addresses: 0h - 818h
L0322: Buffer checksum in range of [0h..1FFFh]: 001FB998h - Byte sum (x8)
L0323: File loading successful.
L0324:
L0325: >> 24.02.2012, 20:39:07
L0326: Loading file (from "Load file" dialog window): C:\Users\Cian\Desktop\Fri\Will_it.hex
L0327: File format selection: automatic
L0328: File format: IntelHEX
L0329: Negative offset (manual): 00000000h
L0330: Range of addresses: 0h - 818h
L0331: File loading successful.
L0332: Buffer checksum in range of [0h..1FFFh]: 001FB998h - Byte sum (x8)
L0333:
L0334: >> 24.02.2012, 20:39:10
L0335: Reading device: Atmel AT89S52.
L0336: Device insertion test ...
L0337: Checking device ID ...
L0338: Reading device ...
L0339: Verifying device with buffer ...
L0340: Reading device - done.
L0341: Elapsed time: 0:00:04.3
L0342: Buffer checksum in range of [0h..1FFFh]: 001FE000h - Byte sum (x8)
L0343: Statistics info: Success:9 Failure:0 Other failure:0 Total:9
L0344:
L0345: >> 24.02.2012, 20:39:33
L0346: Selected device (by Select): Atmel AT89S52 [PLCC44].
L0347: Buffer checksum in range of [0h..1FFFh]: 001FE000h - Byte sum (x8)
L0348: --------------------------
L0349: Device operation options:
L0350: --------------------------
L0351: - Addresses
L0352: Device start: 0000000000
L0353: Device end: 0000001FFF
L0354: Buffer start: 0000000000
L0355: Split: None
L0356: - Insertion test and/or ID check
L0357: Insertion test: Enable
L0358: Device ID check error terminates the operation: Enable
L0359: - Command execution
L0360: Erase before programming: Disable
L0361: Blank check before programming: Disable
L0362: Verify after reading: Enable
L0363: Verify: Once
L0364: Verify options: Not supported
L0365: - Programming parameters
L0366: [ ] Flash
L0367: [ ] Lock bits
L0368: ---------------------
L0369: View/Edit lock bits:
L0370: ---------------------
L0371: [ ] Lock bit 1
L0372: [ ] Lock bit 2
L0373: [ ] Lock bit 3
L0374: ---- End of options list ----
L0375:
L0376: Selected device: Atmel AT89S52 [PLCC44].
L0377: Buffer checksum in range of [0h..1FFFh]: 001FE000h - Byte sum (x8)
L0378:
L0379: >> 24.02.2012, 20:39:49
L0380: --------------------------
L0381: Device operation options:
L0382: --------------------------
L0383: - Addresses
L0384: Device start: 0000000000
L0385: Device end: 0000001FFF
L0386: Buffer start: 0000000000
L0387: Split: None
L0388: - Insertion test and/or ID check
L0389: Insertion test: Enable
L0390: Device ID check error terminates the operation: Enable
L0391: - Command execution
L0392: Erase before programming: Disable
L0393: Blank check before programming: Disable
L0394: Verify after reading: Enable
L0395: Verify: Once
L0396: Verify options: Not supported
L0397: - Programming parameters
L0398: [x] Flash
L0399: [ ] Lock bits
L0400:
L0401: >> 24.02.2012, 20:39:50
L0402: Programming device: Atmel AT89S52 [PLCC44].
L0403: Buffer checksum in range of [0h..1FFFh]: 001FE000h - Byte sum (x8)
L0404: Device insertion test ...
L0405: Checking device ID ...
L0406: Programming device ...
L0407: Verifying device with buffer ...
L0408: Programming device - O.K.
L0409: Elapsed time: 0:00:02.9
L0410: Statistics info: Success:1 Failure:0 Other failure:0 Total:1
L0411:
L0412: >> 24.02.2012, 20:43:30
L0413: Verifying device: Atmel AT89S52 [PLCC44].
L0414: Buffer checksum in range of [0h..1FFFh]: 001FE000h - Byte sum (x8)
L0415: Device insertion test ...
L0416: Checking device ID ...
L0417: Verifying device with buffer ...
L0418: Verifying device - O.K.
L0419: Elapsed time: 0:00:02.8
L0420: Statistics info: Success:2 Failure:0 Other failure:0 Total:2
L0421:
L0422: >> 24.02.2012, 20:44:03
L0423: Verifying device: Atmel AT89S52 [PLCC44].
L0424: Buffer checksum in range of [0h..1FFFh]: 001FE000h - Byte sum (x8)
L0425: Device insertion test ...
L0426: Checking device ID ...
L0427: Verifying device with buffer ...
L0428: Verifying device - O.K.
L0429: Elapsed time: 0:00:02.6
L0430: Statistics info: Success:3 Failure:0 Other failure:0 Total:3
L0431:
L0432: >> 24.02.2012, 20:44:14
L0433: Erasing device: Atmel AT89S52 [PLCC44].
L0434: Device insertion test ...
L0435: Erasing device ...
L0436: Chip erase verify by Blank check procedure ...
L0437: Erasing device - O.K.
L0438: Elapsed time: 0:00:03.3
L0439: Statistics info: Success:4 Failure:0 Other failure:0 Total:4
L0440:
L0441: >> 24.02.2012, 20:44:27
L0442: Select EPROM/Flash by ID.
L0443: Select EPROM/Flash by ID canceled by user!
L0444:
L0445: >> 24.02.2012, 20:44:32
L0446: Select EPROM/Flash by ID.
L0447: Select EPROM/Flash by ID canceled by user!
L0448:
L0449: >> 24.02.2012, 20:44:46
L0450: Blank checking device: Atmel AT89S52 [PLCC44].
L0451: Device insertion test ...
L0452: Checking device ID ...
L0453: Device blank checking ...
L0454: Device blank checking - O.K.
L0455: Elapsed time: 0:00:02.6
L0456: Statistics info: Success:5 Failure:0 Other failure:0 Total:5
L0457:
L0458: >> 24.02.2012, 20:45:04
L0459: Selected device (by Select): Atmel AT89S52 [TQFP44].
L0460: Buffer checksum in range of [0h..1FFFh]: 001FE000h - Byte sum (x8)
L0461: --------------------------
L0462: Device operation options:
L0463: --------------------------
L0464: - Addresses
L0465: Device start: 0000000000
L0466: Device end: 0000001FFF
L0467: Buffer start: 0000000000
L0468: Split: None
L0469: - Insertion test and/or ID check
L0470: Insertion test: Enable
L0471: Device ID check error terminates the operation: Enable
L0472: - Command execution
L0473: Erase before programming: Disable
L0474: Blank check before programming: Disable
L0475: Verify after reading: Enable
L0476: Verify: Once
L0477: Verify options: Not supported
L0478: - Programming parameters
L0479: [ ] Flash
L0480: [ ] Lock bits
L0481: ---------------------
L0482: View/Edit lock bits:
L0483: ---------------------
L0484: [ ] Lock bit 1
L0485: [ ] Lock bit 2
L0486: [ ] Lock bit 3
L0487: ---- End of options list ----
L0488:
L0489: Selected device: Atmel AT89S52 [TQFP44].
L0490: Buffer checksum in range of [0h..1FFFh]: 001FE000h - Byte sum (x8)
L0491:
L0492: >> 24.02.2012, 20:45:12
L0493: Loading file (from "Load file" dialog window): C:\Users\Cian\Desktop\Fri\Will_it.hex
L0494: File format selection: automatic
L0495: File format: IntelHEX
L0496: Negative offset (manual): 00000000h
L0497: Range of addresses: 0h - 818h
L0498: File loading successful.
L0499: Buffer checksum in range of [0h..1FFFh]: 001FD34Fh - Byte sum (x8)
L0500:
L0501: >> 24.02.2012, 20:45:25
L0502: --------------------------
L0503: Device operation options:
L0504: --------------------------
L0505: - Addresses
L0506: Device start: 0000000000
L0507: Device end: 0000001FFF
L0508: Buffer start: 0000000000
L0509: Split: None
L0510: - Insertion test and/or ID check
L0511: Insertion test: Enable
L0512: Device ID check error terminates the operation: Enable
L0513: - Command execution
L0514: Erase before programming: Disable
L0515: Blank check before programming: Disable
L0516: Verify after reading: Enable
L0517: Verify: Once
L0518: Verify options: Not supported
L0519: - Programming parameters
L0520: [x] Flash
L0521: [ ] Lock bits
L0522:
L0523: >> 24.02.2012, 20:45:27
L0524: Programming device: Atmel AT89S52 [TQFP44].
L0525: Buffer checksum in range of [0h..1FFFh]: 001FD34Fh - Byte sum (x8)
L0526: Device insertion test ...
L0527: Checking device ID ...
L0528: Programming device ...
L0529: Verifying device with buffer ...
L0530: Programming device - O.K.
L0531: Elapsed time: 0:00:02.9
L0532: Statistics info: Success:1 Failure:0 Other failure:0 Total:1
L0533:
L0534: >> 24.02.2012, 20:45:36
L0535: Blank checking device: Atmel AT89S52 [TQFP44].
L0536: Device insertion test ...
L0537: Checking device ID ...
L0538: Device blank checking ...
L0539: Device blank checking - error!
L0540: ADR=0000h DI=02h ST=0000h
L0541: Elapsed time: 0:00:02.6
L0542: Statistics info: Success:1 Failure:1 Other failure:0 Total:2
L0543:
L0544: >> 24.02.2012, 20:45:45
L0545: Verifying device: Atmel AT89S52 [TQFP44].
L0546: Buffer checksum in range of [0h..1FFFh]: 001FD34Fh - Byte sum (x8)
L0547: Device insertion test ...
L0548: Checking device ID ...
L0549: Verifying device with buffer ...
L0550: Verifying device - O.K.
L0551: Elapsed time: 0:00:02.6
L0552: Statistics info: Success:2 Failure:1 Other failure:0 Total:3
L0553:
L0554: >> 24.02.2012, 20:45:56
L0555: Reading device: Atmel AT89S52 [TQFP44].
L0556: Device insertion test ...
L0557: Checking device ID ...
L0558: Reading device ...
L0559: Verifying device with buffer ...
L0560: Reading device - done.
L0561: Elapsed time: 0:00:04.3
L0562: Buffer checksum in range of [0h..1FFFh]: 001FD34Fh - Byte sum (x8)
L0563: Statistics info: Success:3 Failure:1 Other failure:0 Total:4
L0564:
L0565: >> 24.02.2012, 20:47:10
L0566: Verifying device: Atmel AT89S52 [TQFP44].
L0567: Buffer checksum in range of [0h..1FFFh]: 001FD34Fh - Byte sum (x8)
L0568: Device insertion test ...
L0569: Checking device ID ...
L0570: Verifying device with buffer ...
L0571: Verifying device - error!
L0572:
L0573: Verify - error(s)
L0574:
L0575: ADDRESS DEVICE BUFFER | ADDRESS DEVICE BUFFER | ADDRESS DEVICE BUFFER
L0576: ------------------------|-------------------------|------------------------
L0577: 00000002 3F 0D | 0000080F 00 E4 | 0000081E E4 FF
L0578: 00000800 E4 75 | 00000810 01 F6 | 0000081F 22 FF
L0579: 00000801 FD 90 | 00000811 0A D8 | 00000820 75 FF
L0580: 00000802 FC FF | 00000812 BA FD | 00000821 90 FF
L0581: 00000803 C3 D2 | 00000813 01 75 | 00000823 D2 FF
L0582: 00000804 ED B0 | 00000814 F8 81 | 00000824 B0 FF
L0583: 00000805 9F D2 | 00000815 BB 07 | 00000825 D2 FF
L0584: 00000806 EC B7 | 00000816 F4 02 | 00000826 B7 FF
L0585: 00000807 9E D2 | 00000817 F5 08 | 00000827 D2 FF
L0586: 00000808 50 A0 | 00000818 0D 00 | 00000828 A0 FF
L0587: 00000809 15 D2 | 00000819 BD FF | 00000829 7F FF
L0588: 0000080A E4 A2 | 0000081A 00 FF | 0000082A C8 FF
L0589: 0000080B FB 80 | 0000081B 01 FF | 0000082B 7E FF
L0590: 0000080D 0B 78 | 0000081C 0C FF | 0000082C 00 FF
L0591: 0000080E BB 7F | 0000081D 80 FF | 0000082D 12 FF
L0592:
L0593: Elapsed time: 0:00:03.0
L0594: Statistics info: Success:3 Failure:2 Other failure:0 Total:5
L0595:
L0596: >> 24.02.2012, 20:47:42
L0597: Called reset statistics counter menu, confirmed by user.
L0598:
L0599: >> 24.02.2012, 20:47:42
L0600: Statistics counters were cleared to zero by user.
L0601:
L0602: >> 24.02.2012, 20:47:45
L0603: Verifying device: Atmel AT89S52 [TQFP44].
L0604: Buffer checksum in range of [0h..1FFFh]: 001FD34Fh - Byte sum (x8)
L0605: Device insertion test ...
L0606: Checking device ID ...
L0607: Verifying device with buffer ...
L0608: Verifying device - error!
L0609:
L0610: Verify - error(s)
L0611:
L0612: ADDRESS DEVICE BUFFER | ADDRESS DEVICE BUFFER | ADDRESS DEVICE BUFFER
L0613: ------------------------|-------------------------|------------------------
L0614: 00000002 3F 0D | 0000080F 00 E4 | 0000081E E4 FF
L0615: 00000800 E4 75 | 00000810 01 F6 | 0000081F 22 FF
L0616: 00000801 FD 90 | 00000811 0A D8 | 00000820 75 FF
L0617: 00000802 FC FF | 00000812 BA FD | 00000821 90 FF
L0618: 00000803 C3 D2 | 00000813 01 75 | 00000823 D2 FF
L0619: 00000804 ED B0 | 00000814 F8 81 | 00000824 B0 FF
L0620: 00000805 9F D2 | 00000815 BB 07 | 00000825 D2 FF
L0621: 00000806 EC B7 | 00000816 F4 02 | 00000826 B7 FF
L0622: 00000807 9E D2 | 00000817 F5 08 | 00000827 D2 FF
L0623: 00000808 50 A0 | 00000818 0D 00 | 00000828 A0 FF
L0624: 00000809 15 D2 | 00000819 BD FF | 00000829 7F FF
L0625: 0000080A E4 A2 | 0000081A 00 FF | 0000082A C8 FF
L0626: 0000080B FB 80 | 0000081B 01 FF | 0000082B 7E FF
L0627: 0000080D 0B 78 | 0000081C 0C FF | 0000082C 00 FF
L0628: 0000080E BB 7F | 0000081D 80 FF | 0000082D 12 FF
L0629:
L0630: Elapsed time: 0:00:02.9
L0631: Statistics info: Success:0 Failure:1 Other failure:0 Total:1
L0632:
L0633: -------------------------------------------------
L0634: -- Creating problem report file --
L0635: -- Date: 24/02/2012 20:48:06 --
L0636: -------------------------------------------------
L0637: --------------------------
L0638: Device operation options:
L0639: --------------------------
L0640: - Addresses
L0641: Device start: 0000000000
L0642: Device end: 0000001FFF
L0643: Buffer start: 0000000000
L0644: Split: None
L0645: - Insertion test and/or ID check
L0646: Insertion test: Enable
L0647: Device ID check error terminates the operation: Enable
L0648: - Command execution
L0649: Erase before programming: Disable
L0650: Blank check before programming: Disable
L0651: Verify after reading: Enable
L0652: Verify: Once
L0653: Verify options: Not supported
L0654: - Programming parameters
L0655: [x] Flash
L0656: [ ] Lock bits
L0657: ---------------------
L0658: View/Edit lock bits:
L0659: ---------------------
L0660: [ ] Lock bit 1
L0661: [ ] Lock bit 2
L0662: [ ] Lock bit 3
L0663:
L0664: SN: 233-05963
L0665: PCBV: 5
L0666: PCBR: 0
L0667: BV: 0001H
L0668: ID: 001E/0052/0006
L0669:
L0670: --------- Active device drivers ---------
L0671: #0 MEDIA | HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_104D4600&REV_1000 | Realtek High Definition Audio
L0672: #1 Net | *6to4mp | Microsoft 6to4 Adapter
L0673: #2 Net | ms_sstpminiport | WAN Miniport (SSTP)
L0674: #3 Net | *6to4mp | Microsoft 6to4 Adapter
L0675: #4 System | ACPI\ThermalZone | ACPI Thermal Zone
L0676: #5 LegacyDriver | | Ancillary Function Driver for Winsock
L0677: #6 Net | *6to4mp | Microsoft 6to4 Adapter
L0678: #7 VolumeSnapshot | STORAGE\VolumeSnapshot | Generic volume shadow copy
L0679: #8 LegacyDriver | | NetIO Legacy TDI Support Driver
L0680: #9 System | ROOT\RDP_KBD | Terminal Server Keyboard Driver
L0681: #10 Net | *6to4mp | Microsoft 6to4 Adapter
L0682: #11 Volume | STORAGE\Volume | Generic volume
L0683: #12 System | ACPI_HAL\PNP0C08 | Microsoft ACPI-Compliant System
L0684: #13 Net | *6to4mp | Microsoft 6to4 Adapter
L0685: #14 LegacyDriver | | NSI proxy service driver.
L0686: #15 LegacyDriver | | Bitlocker Drive Encryption Filter Driver
L0687: #16 USB | PCI\VEN_8086&DEV_3B34&SUBSYS_9071104D&REV_05 | Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
L0688: #17 System | ROOT\RDP_MOU | Terminal Server Mouse Driver
L0689: #18 Net | *6to4mp | Microsoft 6to4 Adapter
L0690: #19 hdc | PCI\VEN_1180&DEV_E822&SUBSYS_9071104D&REV_00 | Ricoh PCIe SD Bus Host Adapter
L0691: #20 System | PCI\VEN_8086&DEV_2D10&SUBSYS_9071104D&REV_02 | QPI Link 0 - 2D10
L0692: #21 System | ACPI\INT0800 | Intel(R) 82802 Firmware Hub Device
L0693: #22 Net | *6to4mp | Microsoft 6to4 Adapter
L0694: #23 LegacyDriver | | Mount Point Manager
L0695: #24 SCSIAdapter | *mcdbusdevice | MagicISO SCSI Host Controller
L0696: #25 Net | *6to4mp | Microsoft 6to4 Adapter
L0697: #26 LegacyDriver | | VgaSave
L0698: #27 LegacyDriver | | HTTP
L0699: #28 VolumeSnapshot | STORAGE\VolumeSnapshot | Generic volume shadow copy
L0700: #29 MEDIA | HDAUDIO\FUNC_01&VEN_8086&DEV_2804&SUBSYS_104D4600&REV_1000 | Intel(R) Display Audio
L0701: #30 Net | *6to4mp | Microsoft 6to4 Adapter
L0702: #31 System | ACPI\PNP0000 | Programmable interrupt controller
L0703: #32 Net | *6to4mp | Microsoft 6to4 Adapter
L0704: #33 System | root\swenum | Plug and Play Software Device Enumerator
L0705: #34 LegacyDriver | | Null
L0706: #35 LegacyDriver | | Hardware Policy Driver
L0707: #36 LegacyDriver | | Dynamic Volume Manager
L0708: #37 Net | *6to4mp | Microsoft 6to4 Adapter
L0709: #38 System | ACPI\PNP0100 | System timer
L0710: #39 Net | *6to4mp | Microsoft 6to4 Adapter
L0711: #40 USB | PCI\VEN_8086&DEV_3B3C&SUBSYS_9071104D&REV_05 | Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
L0712: #41 Volume | STORAGE\Volume | Generic volume
L0713: #42 System | root\umbus | UMBus Root Bus Enumerator
L0714: #43 System | PCI\VEN_8086&DEV_2D11&SUBSYS_9071104D&REV_02 | QPI Physical 0 - 2D11
L0715: #44 Net | PCI\VEN_11AB&DEV_4381&SUBSYS_9071104D&REV_11 | Marvell Yukon 88E8059 PCI-E Gigabit Ethernet Controller
L0716: #45 LegacyDriver | | Performance Counters for Windows Driver
L0717: #46 Net | *6to4mp | Microsoft 6to4 Adapter
L0718: #47 VolumeSnapshot | STORAGE\VolumeSnapshot | Generic volume shadow copy
L0719: #48 LegacyDriver | | Microsoft Malware Protection Network Driver
L0720: #49 LegacyDriver | | KSecDD
L0721: #50 Battery | ACPI\ACPI0003 | Microsoft AC Adapter
L0722: #51 LegacyDriver | | Storage volumes
L0723: #52 Net | *6to4mp | Microsoft 6to4 Adapter
L0724: #53 System | ROOT\vdrvroot | Microsoft Virtual Drive Enumerator Driver
L0725: #54 System | ACPI\PNP0103 | High precision event timer
L0726: #55 Net | *6to4mp | Microsoft 6to4 Adapter
L0727: #56 LegacyDriver | | PEAUTH
L0728: #57 LegacyDriver | | KSecPkg
L0729: #58 Net | *6to4mp | Microsoft 6to4 Adapter
L0730: #59 Net | {5d624f94-8850-40c3-a3fa-a4fd2080baf3}\vwifimp | Microsoft Virtual WiFi Miniport Adapter
L0731: #60 LegacyDriver | | Windows Firewall Authorization Driver
L0732: #61 System | ROOT\VOLMGR | Volume Manager
L0733: #62 System | ACPI\PNP0200 | Direct memory access controller
L0734: #63 Processor | ACPI\GenuineIntel_-_Intel64_Family_6_Model_37 | Intel Processor
L0735: #64 LegacyDriver | | Virtual WiFi Filter Driver
L0736: #65 Net | *6to4mp | Microsoft 6to4 Adapter
L0737: #66 LegacyDriver | | QoS Packet Scheduler
L0738: #67 Net | *6to4mp | Microsoft 6to4 Adapter
L0739: #68 Net | *6to4mp | Microsoft 6to4 Adapter
L0740: #69 VolumeSnapshot | STORAGE\VolumeSnapshot | Generic volume shadow copy
L0741: #70 CDROM | SCSI\CdRom&Ven_MagicISO&Prod_Virtual_DVD-ROM&Rev_1.0A | CD-ROM Drive
L0742: #71 System | PCI\VEN_8086&DEV_3B42&SUBSYS_9071104D&REV_05 | Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 1 - 3B42
L0743: #72 System | PCI\VEN_8086&DEV_2D12&SUBSYS_9071104D&REV_02 | Reserved - 2D12
L0744: #73 LegacyDriver | | Link-Layer Topology Discovery Mapper I/O Driver
L0745: #74 USB | USB\VID_0C45&PID_6464&REV_0102 | USB Composite Device
L0746: #75 Net | *6to4mp | Microsoft 6to4 Adapter
L0747: #76 Net | PCI\VEN_168C&DEV_002B&SUBSYS_E017105B&REV_01 | Atheros AR9285 Wireless Network Adapter
L0748: #77 Keyboard | ACPI\PNP0303 | Standard PS/2 Keyboard
L0749: #78 LegacyDriver | | Remote Access IPv6 ARP Driver
L0750: #79 Net | *6to4mp | Microsoft 6to4 Adapter
L0751: #80 Net | *6to4mp | Microsoft 6to4 Adapter
L0752: #81 VolumeSnapshot | STORAGE\VolumeSnapshot | Generic volume shadow copy
L0753: #82 Net | *6to4mp | Microsoft 6to4 Adapter
L0754: #83 Net | *6to4mp | Microsoft 6to4 Adapter
L0755: #84 Net | *6to4mp | Microsoft 6to4 Adapter
L0756: #85 System | ACPI\PNP0A03 | PCI bus
L0757: #86 USB | USB\VID_8087&PID_0020&REV_0000 | Generic USB Hub
L0758: #87 LegacyDriver | | Kernel Mode Driver Frameworks service
L0759: #88 DevPgmUSB | USB\VID_1393&PID_0579&REV_8004 | DATAMAN-40PRO, Universal 40-pindrive Programmer
L0760: #89 Image | USB\VID_0C45&PID_6464&REV_0102&MI_00 | USB Video Device
L0761: #90 LegacyDriver | | RDPCDD
L0762: #91 LegacyDriver | | Beep
L0763: #92 Net | *6to4mp | Microsoft 6to4 Adapter
L0764: #93 VolumeSnapshot | STORAGE\VolumeSnapshot | Generic volume shadow copy
L0765: #94 System | ACPI\PNP0A08 | PCI bus
L0766: #95 Net | *6to4mp | Microsoft 6to4 Adapter
L0767: #96 Net | *6to4mp | Microsoft 6to4 Adapter
L0768: #97 VolumeSnapshot | STORAGE\VolumeSnapshot | Generic volume shadow copy
L0769: #98 System | PCI\VEN_8086&DEV_3B44&SUBSYS_9071104D&REV_05 | Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 2 - 3B44
L0770: #99 System | PCI\VEN_8086&DEV_2D13&SUBSYS_9071104D&REV_02 | Reserved - 2D13
L0771: #100 LegacyDriver | | WFP Lightweight Filter
L0772: #101 Net | *6to4mp | Microsoft 6to4 Adapter
L0773: #102 VolumeSnapshot | STORAGE\VolumeSnapshot | Generic volume shadow copy
L0774: #103 LegacyDriver | | RDP Encoder Mirror Driver
L0775: #104 System | PCI\VEN_8086&DEV_0044&SUBSYS_9071104D&REV_02 | Intel(R) processor DRAM Controller - 0044
L0776: #105 System | ACPI\PNP0B00 | System CMOS/real time clock
L0777: #106 Net | *6to4mp | Microsoft 6to4 Adapter
L0778: #107 Net | *6to4mp | Microsoft 6to4 Adapter
L0779: #108 USB | USB\VID_8087&PID_0020&REV_0000 | Generic USB Hub
L0780: #109 Processor | ACPI\GenuineIntel_-_Intel64_Family_6_Model_37 | Intel Processor
L0781: #110 Net | *6to4mp | Microsoft 6to4 Adapter
L0782: #111 LegacyDriver | | User Mode Driver Frameworks Platform Driver
L0783: #112 Net | *6to4mp | Microsoft 6to4 Adapter
L0784: #113 Net | *6to4mp | Microsoft 6to4 Adapter
L0785: #114 CDROM | IDE\CdRomMATSHITA_DVD-RAM_UJ8A0AS________________1.00____ | CD-ROM Drive
L0786: #115 VolumeSnapshot | STORAGE\VolumeSnapshot | Generic volume shadow copy
L0787: #116 LegacyDriver | | Reflector Display Driver used to gain access to graphics data
L0788: #117 System | ACPI\PNP0C02 | Motherboard resources
L0789: #118 Net | *6to4mp | Microsoft 6to4 Adapter
L0790: #119 LegacyDriver | | msisadrv
L0791: #120 Net | *6to4mp | Microsoft 6to4 Adapter
L0792: #121 Net | *6to4mp | Microsoft 6to4 Adapter
L0793: #122 System | ROOT\mssmbios | Microsoft System Management BIOS Driver
L0794: #123 System | ACPI\PNP0C02 | Motherboard resources
L0795: #124 Net | *6to4mp | Microsoft 6to4 Adapter
L0796: #125 System | PCI\VEN_8086&DEV_3B09&SUBSYS_9071104D&REV_05 | Intel(R) HM55 Express Chipset LPC Interface Controller - 3B09
L0797: #126 LegacyDriver | | Link-Layer Topology Discovery Responder
L0798: #127 System | PCI\VEN_8086&DEV_3B46&SUBSYS_9071104D&REV_05 | Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 3 - 3B46
L0799: #128 Net | *6to4mp | Microsoft 6to4 Adapter
L0800: #129 Net | *6to4mp | Microsoft 6to4 Adapter
L0801: #130 Display | PCI\VEN_8086&DEV_0046&SUBSYS_9071104D&REV_02 | Intel(R) HD Graphics
L0802: #131 System | ACPI\PNP0C04 | Numeric data processor
L0803: #132 Net | ms_agilevpnminiport | WAN Miniport (IKEv2)
L0804: #133 LegacyDriver | | Common Log (CLFS)
L0805: #134 Net | *6to4mp | Microsoft 6to4 Adapter
L0806: #135 LegacyDriver | | Security Driver
L0807: #136 Net | *6to4mp | Microsoft 6to4 Adapter
L0808: #137 LegacyDriver | | NativeWiFi Filter
L0809: #138 System | ACPI\PNP0C09 | Microsoft ACPI-Compliant Embedded Controller
L0810: #139 Net | *6to4mp | Microsoft 6to4 Adapter
L0811: #140 LegacyDriver | | CNG
L0812: #141 Net | ms_l2tpminiport | WAN Miniport (L2TP)
L0813: #142 Net | *6to4mp | Microsoft 6to4 Adapter
L0814: #143 DiskDrive | IDE\DiskST9320325AS_____________________________0006SDM2 | Disk drive
L0815: #144 LegacyDriver | | Security Processor Loader Driver
L0816: #145 Processor | ACPI\GenuineIntel_-_Intel64_Family_6_Model_37 | Intel Processor
L0817: #146 Net | *6to4mp | Microsoft 6to4 Adapter
L0818: #147 hdc | PCI\VEN_8086&DEV_3B29&SUBSYS_9071104D&REV_05 | Intel(R) 5 Series 4 Port SATA AHCI Controller
L0819: #148 System | PCI\VEN_8086&DEV_3B4C&SUBSYS_9071104D&REV_05 | Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 6 - 3B4C
L0820: #149 Battery | ACPI\PNP0C0A | Microsoft ACPI-Compliant Control Method Battery
L0821: #150 LegacyDriver | | NDIS System Driver
L0822: #151 Net | *ISATAP | Microsoft ISATAP Adapter
L0823: #152 Net | *6to4mp | Microsoft 6to4 Adapter
L0824: #153 System | UMB\UMBUS | UMBus Enumerator
L0825: #154 Net | ms_ndiswanbh | WAN Miniport (Network Monitor)
L0826: #155 System | PCI\VEN_8086&DEV_2448&SUBSYS_9071104D&REV_A5 | Intel(R) 82801 PCI Bridge - 2448
L0827: #156 Net | *6to4mp | Microsoft 6to4 Adapter
L0828: #157 System | ACPI\PNP0C0C | ACPI Power Button
L0829: #158 Net | *6to4mp | Microsoft 6to4 Adapter
L0830: #159 LegacyDriver | | NDIS Usermode I/O Protocol
L0831: #160 LegacyDriver | | System Attribute Cache
L0832: #161 Net | ms_ndiswanip | WAN Miniport (IP)
L0833: #162 Net | *6to4mp | Microsoft 6to4 Adapter
L0834: #163 Net | *TEREDO | Microsoft Teredo Tunneling Adapter
L0835: #164 Net | *6to4mp | Microsoft 6to4 Adapter
L0836: #165 System | ACPI\PNP0C0D | ACPI Lid
L0837: #166 LegacyDriver | | NDProxy
L0838: #167 LegacyDriver | | LDDM Graphics Subsystem
L0839: #168 Net | *6to4mp | Microsoft 6to4 Adapter
L0840: #169 Net | ms_ndiswanipv6 | WAN Miniport (IPv6)
L0841: #170 System | PCI\VEN_8086&DEV_3B30&SUBSYS_9071104D&REV_05 | Intel(R) 5 Series/3400 Series Chipset Family SMBus Controller - 3B30
L0842: #171 hdc | PCI\VEN_1180&DEV_E230&SUBSYS_9071104D&REV_00 | Ricoh PCIe Memory Stick Host Controller
L0843: #172 Computer | acpiapic | ACPI x64-based PC
L0844: #173 Net | *6to4mp | Microsoft 6to4 Adapter
L0845: #174 System | PCI\VEN_8086&DEV_3B56&SUBSYS_9071104D&REV_05 | High Definition Audio Controller
L0846: #175 System | PCI\VEN_8086&DEV_2C62&SUBSYS_9071104D&REV_02 | QuickPath Architecture Generic Non-core Registers - 2C62
L0847: #176 Net | *6to4mp | Microsoft 6to4 Adapter
L0848: #177 HIDClass | ACPI\SNY5001 | Sony Firmware Extension Parser Device
L0849: #178 Net | *6to4mp | Microsoft 6to4 Adapter
L0850: #179 System | ROOT\BLBDRIVE | File as Volume Driver
L0851: #180 USB | USB\ROOT_HUB20&VID8086&PID3B34&REV0005 | USB Root Hub
L0852: #181 Net | ms_pppoeminiport | WAN Miniport (PPPOE)
L0853: #182 LegacyDriver | | szkg5
L0854: #183 Net | *6to4mp | Microsoft 6to4 Adapter
L0855: #184 Processor | ACPI\GenuineIntel_-_Intel64_Family_6_Model_37 | Intel Processor
L0856: #185 Monitor | MONITOR\SNY05FA | Generic PnP Monitor
L0857: #186 Mouse | ACPI\SNYALP0012 | Alps Pointing-device
L0858: #187 Net | *6to4mp | Microsoft 6to4 Adapter
L0859: #188 Volume | STORAGE\Volume | Generic volume
L0860: #189 System | ROOT\CompositeBus | Composite Bus Enumerator
L0861: #190 LegacyDriver | | NETBT
L0862: #191 LegacyDriver | | TCP/IP Protocol Driver
L0863: #192 Net | *6to4mp | Microsoft 6to4 Adapter
L0864: #193 USB | USB\ROOT_HUB20&VID8086&PID3B3C&REV0005 | USB Root Hub
L0865: #194 VolumeSnapshot | STORAGE\VolumeSnapshot | Generic volume shadow copy
L0866: #195 Net | ms_pptpminiport | WAN Miniport (PPTP)
L0867: #196 Net | *6to4mp | Microsoft 6to4 Adapter
L0868: #197 System | PCI\VEN_8086&DEV_3B32&SUBSYS_9071104D&REV_05 | Intel(R) Turbo Boost Technology Driver
L0869: #198 System | PCI\VEN_8086&DEV_3B64&SUBSYS_9071104D&REV_06 | Intel(R) Management Engine Interface
L0870: #199 SDHost | PCI\VEN_1180&DEV_E822&SUBSYS_9071104D&REV_00 | SDA Standard Compliant SD Host Controller
L0871: #200 Battery | COMPOSITE_BATTERY | Microsoft Composite Battery
L0872: #201 Net | *6to4mp | Microsoft 6to4 Adapter
L0873: #202 System | PCI\VEN_8086&DEV_2D01&SUBSYS_9071104D&REV_02 | QuickPath Architecture System Address Decoder - 2D01
L0874: #203 System | ACPI\ThermalZone | ACPI Thermal Zone
L0875: #204 LegacyDriver | | Microsoft Network Inspection System
L0876: #205 LegacyDriver | | TCP/IP Registry Compatibility
Re: Help
Postby Dataman (Neil Parker) » 27 Feb 2012 15:57
Hello cyoung,
It is not clear from your log file what the problem is. It shows several times a successful blank check on a device followed by several successful program and verify procedures. This would indicate to me that the device has been programmed correctly. Unless you have set the lock bits (protected the device) you will be able to remove the programmed device from the programmer and return it to perform a verify which should also pass unless the data in the device has been modified somehow.
Please close the control software and reopen it, recreate the error you describe and then generate a problem report. This should produce a clearer log file and I should be able to see what's going on and hopefully offer some help.
Return to “Dataman 40Pro”
