I use Datama48XP I have generated a project .P48 that it uses the ST62T01C micro. The relative Option byte is correctly configurated. Once programmed micro, if Y read it, the Option byte is empty.
Sorry for my english..
NeUser
D48XP Option Byte ST62T01C
Re: D48XP Option Byte ST62T01C
NeUser,
Programming the data onto the device and programming the configuration data are two separate processes. Once you have hit the program button and it has completed, you then have to hit the protect button which will program the configuration and/or protect the device.
Hope this helps.
Hope this helps.
Neil,
I have had this problem when I have carried out the upgrade from dataman 48lv to XP and have regenerated the rows project .PRJ to .P48. With version 48LV the Option Byte was shaped correctly.
NeUser
NeUser
NeUser
So even after setting the configuration options and burning them into the device the configuration bytes are wrong. Is this correct?
Neil,
Yes it is corect.
This problem exists alone on ST62T01C, while in other types of mcu as ST62T10C or ST662T15C all works regularly.
NeUser
Yes it is corect.
NeUser
I need your help in this case.
1) pls send me 3 pcs blank chip and also 2 pcs of the chip that you claim does not program the configuration correctly.
2) pls also give me the file and the set up of the configuration.
The algorithm for this chip has never changed since its release 7 years ago, it shares the same source code with both Dataman-48 and Dataman-48XP, I have no blank chips to test since it is a
very old chip,
I need you to provide the above support otherwise I can not help.
very old chip,
