New software - Version 3.33
Postby Dataman (Daniel Smith) » 30 Jun 2017 11:31
Added support of AP1 QFN40-1.02 ZIF LT-1 module
Added support of AP1 QFP100 ZIF LPC-1 module
Added support of AP1 QFP64-3 ZIF NEC-2 module
