DM 48UXP
DM 48UXP
Postby Guest » 11 Nov 2011 11:55
Hi Neil can you tell me if the 48uxp can read write S29AL016M90TF and M59W640F none of these are listed in the data base.
Regards Albert
Re: DM 48UXP
Postby Dataman (Neil Parker) » 11 Nov 2011 11:56
Hi Albert,
The D48UXP supports the S29AL016 device but not the M59W640 one. This looks to be a new device and there isnt much information about it on the web. If you could source a data sheet for it then we can look into supporting it.
Re: DM 48UXP
Postby Guest » 11 Nov 2011 11:56
i,ve only ever seen the M59W640F used in the SA 8300 cable receiver and i have only found this
web site http://www.data-io.com/device/support_l ... rog=FLX500 that has anything on it
if you go to ST.COMs web site the M59W640F dos not exist
i have also been looking for a data sheet for the device
Re: DM 48UXP
Postby Guest » 11 Nov 2011 11:57
Hi Albert,
Ok Neil many thanks for the info.
I will try to get a data sheet and send it to you.
Regards Albert
Re: DM 48UXP
Postby Guest » 11 Nov 2011 11:58
Many thanks for replying to my plea for help and the info.
Regards Albert
Re: DM 48UXP
Hi Albert,
thanks,can the Intel JS28F160 be read with the d48uxp if so what chip number in the database do i use.
Is it a standard 48 pin tsop adaptor that is needed.
Regards Albert
Re: DM 48UXP
Postby Dataman (Neil Parker) » 11 Nov 2011 11:58
Hi Albert,
Please select E28F160 in the software, the JS means it is RoHs compatible chip it still has all the same spec as the standard 28F160.
The adsptor would be the SDP-UNIV-48TS.
Hope this helps.
Re: DM 48UXP
Postby Guest » 11 Nov 2011 11:59
Hi Albert,
Hope this helps.
Many thanks Neil
Regards Albert
Re: DM 48UXP
Postby Guest » 11 Nov 2011 12:00
Hi Albert,
Hope this helps.
I cant find the E28F160 tsop 48 in my database
Regards Albert
Re: DM 48UXP
Postby Dataman (Neil Parker) » 11 Nov 2011 12:00
Hi Albert,
Please try the TE28F160B/T
