Macronix KH25L6436F [SOP8-200] (Quad I/O), KH25L6436F [SOP8-200], added support
Micron MT25QU128ABA1E [DFN8 8x6] (Quad I/O), added support
New software - Version 3.34
Postby Dataman (Daniel Smith) » 12 Sep 2017 11:58
