Fixed bug in testing AP1 programming modules
Added module: AP1 BGA256-3 ZIF PLD-23 (Enpl)
Added module: AP1 LQFP64-2 ZIF R5F-3
Added module: AP1 QFN64-1.02 ZIF PN-1
New software - Version 3.34
Postby Dataman (Daniel Smith) » 12 Sep 2017 12:01
