I have an S4, and need to replace a faulty 8755 on a piece of equipment. I have access to a 8755 with good 2kb memory. 8755 is not on S4 supported device list, but wondered if just due to low demand. Does anyone know if/how this can be done with S4? If so, which of the S4 modules (40 pin adapter) is needed?
Thanks in advance.
Martin Thiel
Possible to copy Intel 8755 with S4 ?
Re: Possible to copy Intel 8755 with S4 ?
8755 8355
I've find things to contribute to the revovery of data contained in 8755 .
-It's not a MCU but a peripheral interface with IO capabilities. 8355 is
OTP, 8755 Erasable programmable. It have 2k*8 data
- the pins config from chipdir, i'vent find data page on Intel web server
8755
1 -|prog&/ce vcc|- 40
2 -|ce pb7|- 39
3 -|clk pb6|- 38
4 -|reset pb5|- 37
5 -|vdd pb4|- 36
6 -|ready pb3|- 35
7 -|io/m pb2|- 34
8 -|/ior pb1|- 33
9 -|/rd pb0|- 32
10 -|/iow 8755 pa7|- 31
11 -|ale pa6|- 30
12 -|ad0 pa5|- 29
13 -|ad1 pa4|- 28
14 -|ad2 pa3|- 27
15 -|ad3 pa2|- 26
16 -|ad4 pa1|- 25
17 -|ad5 pa0|- 24
18 -|ad6 a10|- 23
19 -|ad7 a9|- 22
20 -|vss a8|- 21
- It's a peripheral which was used by 8085CPU. This cpu use address latch
enable (ALE pin 11) to strobe low A0-A7 address bit in 8755.(internal address
latch from 1983 Intel info book).
- pin 1 prog & /ce i suppose ce low enable cheap and high Vpp to prog
- pin 2 ce suppose /ce and ce the two are in use and inverted
- pin 3 clk from 8085 programming book, this clock is twice x1 x2 cristal
8085 clock.
- pin 4 reset to reset the chip (usualy it is low who reset the chip)
- pin 5-40-20 vdd vcc vss
- pin 6 ready , on 8085 it is a signal to go to cpu to signal chip is ready
(not used on 8085 prog)
- pin 7 io /m i suppose io for high=1 and low=0 for memory
- pin 8-10 /ior /iom for io not in use in that case suppose hight +5v with
resistor
- pin 9 /rd active low=0 read chip (prog=Vpp writte memory?)
- pin 11 ale strobe at the beginning of T cycle , that strobe A0-A7 in 8755
latch, on the falling edge of ale. Ale=0 then up, then low=0.
- Ad0-Ad7 at first T cycle (T1 address latch ) at T2 cycle read, T3 writte
This peripheral need buffers and circuitry to be read.
Trust this info and die. Use at your own risk.
philippe hunter
8755
2 -|ce pb7|- 39
3 -|clk pb6|- 38
4 -|reset pb5|- 37
5 -|vdd pb4|- 36
6 -|ready pb3|- 35
7 -|io/m pb2|- 34
8 -|/ior pb1|- 33
9 -|/rd pb0|- 32
11 -|ale pa6|- 30
12 -|ad0 pa5|- 29
13 -|ad1 pa4|- 28
14 -|ad2 pa3|- 27
15 -|ad3 pa2|- 26
16 -|ad4 pa1|- 25
17 -|ad5 pa0|- 24
18 -|ad6 a10|- 23
19 -|ad7 a9|- 22
20 -|vss a8|- 21
8085 clock.
resistor
philippe hunter
Users browsing this forum: Semrush [Bot] and 3 guests
