New software - Version 2.98
Postby Dataman (Daniel Smith) » 17 May 2013 15:34
Version 2.98 features the following amendments:
Fixed bug in function for open/close ZIF socket en bloc in ZIF socket actuation unit
Now it is possible to select device with larger memory size, then currently available free disk space
Added new functions for open/close particular ZIF sockets in PG4UWMC remote control mode
ABOV Semicond. MC80F0604, programming procedure improved
Atmel ATmega16HVB/32HVB, BOOTSZ fuse bits binary values and bootloader start addresses corrected
Atmel ATSAM3U4EA [LQFP144], programming adapter ord.no. 70-1299 test improved
Atmel AVR8/16 in ZIF, redesign of ALT+S windows, added feature of setting fuses and locks in HEX
eMMC devices, load project improved
eMMC devices, added feature 'Skip programming of blank data'
Freescale Semic. MC9RS08KBx, power up sequence improved
Fujitsu MB9B510/410/310/110 series, programming procedure improved
Macronix MX26L12811MC [PSOP44], erase procedure improved
NAND flash devices, "ECC - Hamming (2 x 256 Byte Frame) variant 1" and "ECC - Hamming (2 x 256 Byte Frame) variant 2" spare area usage modes enabled for all devices
Generalplus GPR25L162B, program and erase procedure improved
Infineon XC161CS-32, power-up sequence improved
Macronix MX25L25735F [SOP16] (Quad I/O), improving of pin assignment
Nordic nRF51xxx, improved load hex file for UICR data
Nordic nRF51xxx, programming and verifying procedure improved
Programming module AP1 QFN8-5 ZIF SFlash-1 released for serial flash devices in QFN8 8x6mm package
Renesas R5F100x, power-on procedure improved
Renesas R5F100x, synchronization procedure improved
STMicroelectronics SPC560B60 [ISP], censorship password unprotect feature added
STMicroelectronics STM8L15x, warning message after selected device remove
Xilinx XCFxxP, adding of array description of an actual array during programming and verification
BOSCH B58097, reading/programming bug fixed
Cypress CY8C3xxxxxx (ISP), CY8C5xxxxxx (ISP), ISP description bug fixed
Freescale Semic. MC9S08QG8 [QFN16], insertion test error fixed
Macronix MX26L12811MC [PSOP44], ID check bug fixed
Microchip PIC18F2xK22, PIC18F4xK22, set of XINST configuration bit bug fixed
Samsung KLMCG8GE4A-A001 [FBGA169], device does not respond - bug fixed
Xilinx XCFxxP, addressing bug fixed
