New software - Version 3.00
Postby Dataman (Daniel Smith) » 23 Sep 2013 16:16
NEC/Renesas uPD78F100x, added support
Samsung HART-m310 (ISP-SPI)/HART-i910 (ISP-SPI), added settings - maximum/80%/60%/40%/20%/10% of maximum for clock signal frequency
SPI
