New software - Version 3.35
Postby Dataman (Daniel Smith) » 20 Oct 2017 14:54
Fixed bug in checking of adapter BGA-Bottom-215 + BGA-Top-117 ZIF (a)
Adapter DIL48/QFN32-1.02 ZIF EFM-3, insertion test improved
Added adapter: DIL48/QFN32-1.02 ZIF TLSR-1
Added adapter: DIL48/QFN40-2.02 ZIF TPS53-3
Added adapter: DIL48/QFN48-2.02 ZIF ISL-1
Atmel/Microchip ATSAM4Sxxx, Blank Check procedure improved
Fixed bug relating to the selection of devices supported by adapter DIL48/QFN40-1.02 ZIF LT-1
