New software - Version 3.35
Postby Dataman (Daniel Smith) » 20 Oct 2017 14:57
Added module: AP1 BGA48-1.02 ZIF NOR-1
Added module: AP1 BGA64-3.1 ZIF NOR-7
Added module: AP1 LQFP64 ZIF R5F-2
Added module: AP1 LQFP80 ZIF H8S-1
Added module: AP1 QFN32 ZIF ARM-1
Added module: AP1 QFN64-1.02 ZIF PN-1
Added module: AP1 QFP144-1.02 ZIF R7F-2
Added module: AP1 QFP64-1.02 ZIF R4F-1
