Hi all!
I´ve recieved an Intel hex file from our distrubutor in the states and need to get it on a Atmel 29c020 chip. For some reason the guy´s over there has designed the file so i must recieve it at FE0000 to FFFFFF in the s4. Can this be done....anyone.
Cheers
/Mattias Anderson
S4/hex file download @ assigned address.....
Re: S4/hex file download @ assigned address.....
Atmel 29c020 and hex file to FE0000 to FFFFFF.
Atmel 29c020 is 256kbyte. So its address range is 0-3FFFF.
a. Fill S4 RAM with FFs
b. You should then send your HEX file to the S4 from PC.
It is then at 60000H to 7FFFFH. I presume you want to burn it at the end of the 29040 chip.
BURN 40000,7FFFF,00000
(or BURN 60000,7FFFF,00000 - only the relevant part)
Hope this helps,
Hope this helps,
That tip was worth its weight in many ours of failure!! Thanks a hole lot! Back in business!!
Cheers
/Mattias Anderson
Cheers
/Mattias Anderson
I created a programm with Intel C for a 80C188 and I want part of the program on a Eprom (64k) and the other part on a Flash Eprom (128K). On my board Eprom has address between F0000 and FFFFF (power on is at FFFF0 according Intel); Flash Eprom has address between 60000 and 7FFFF. If code in Flash exceeds 64k (it exceeds 6FFFF) it overlaps with Eprom code because on S4, when I send hex file from PC, Eprom code is loaded between 70000 and 7FFFF (the upper part of S4 ram). Is it possible to avoid overlapping?
Franco Picchiarini
Franco Picchiarini
