Programme 2708 with Dataman
Postby Guest » 14 Nov 2011 11:53
I want to programme a Texas Instruments 2708 EPROM chip with my S4 prommer. Please can you support this?
C Kavman
Re: Programme 2708 with Dataman
Hi Kavman,
I hav done this..
This simple - select 2716 and ad a 12.1V Zenor from vcc to +25V externol supply.
+25 ----------
VCC
Bye
Yatoto Sackalotto
i tried this, but nothing happen. i get message vpp setting error. can you suggest what is wrong. i have a 12.1V Zenor connected as shown. do i need to use the red write lead?
C Kavman
Postby Guest » 14 Nov 2011 11:54
Mr Kavman
Add capactor and re-sister.
+25v---|-------
| VCC | | 10Ohm re-sister
I dont no Mr write lead, he sound good guy.
Bye
Yatoto Sackalotto
Postby Dataman (Neil Parker) » 14 Nov 2011 11:54
TI 2708 memory requires 3 voltages - +5V,+12V and -5V.
It is NOT possible to program the chip using the method Anonymous has detailed above.
Please, do not attempt this.
The chip also needs proper voltage sequencing.
S4 cannot program it (unless Dataman designs a new module)
Hope this clears things up.
Mr Neil
you are very wise guy, i learn from you.
use Zenor for read only, programe data int 2716 chip.
you come to my country and make lot money.
ibglatocbacofu TW ltd
Bye
Yatoto Sackalotto
Return to “Dataman S4”
