Added module: AP1 BGA64-2.3 NOR-1 (LD)
Added module: AP1 LQFP44 ZIF R5F-1 (LD)
Added module: AP1 QFP44 ZIF XMEGA-1
Added module: AP1 SSOP30-240 ZIF R5F-1
Micron MT25QU02GCBB8E12 [TBGA24] (Quad I/O), added support
New software - Version 3.37
Postby Dataman (Daniel Smith) » 22 Dec 2017 16:32
