I have just downloaded the S4 windows driver (V2.04). Now I'm probably just amazing thick, but I simply cannot work out how to get data into it. I've tried selecting a text file using "examine file", which does nothing useful, and I've tried typing directly into the S4 window, which does nothing at all. And the "help file" appears not to exist. So please is there anywhere I can go to get some basic instruction in using this program? Thanks.
David Looser
S4 Windows Driver V2.04
Re: S4 Windows Driver V2.04
Hi David,
With the S4 driver terminal you basically have a glorified terminal window. You could use windows hyper terminal to communicate with the S4 just as well. To send a file to the S4 you would go to Transfer > Send File (F8) this will bring up a window allowing you to search your pc for the file you whish to transfer, select the file and hit Open. The file will be transferred to the S4.
You must ensure that the S4 and PC are set to the same baud rate and are communicating before you try and transfer a file.
