AT29C256, AT29C512
AT29C256, AT29C512
Postby Guest » 14 Nov 2011 15:13
The AT29C256 and the AT29C512 Flash ROMs are supportable devices according to the lib on my S4, and in fact, I am able to erase them. However, I am unable to program them. Since these are 'used' chips, I suspect that software protection has been enabled. Am I correct in assuming, then, that the Atmel flash programming algorithm used by the S4 does not incorporate the routine needed to bypass this protection? Can someone help me?
Re: AT29C256, AT29C512
Postby Dataman (Neil Parker) » 14 Nov 2011 15:13
Before programming the chips, use FUNC QUICK and select DATA PROTECT OFF (Press ENTER). Then you can program chip.
Let me know if this helps - for both devices.
Return to “Dataman S4”
