MOD40 and 29F200
MOD40 and 29F200
Postby Guest » 14 Nov 2011 15:28
Is it possible to use the MOD40 16 bit adapter to program an 29F200? In the description of the 16-bit library there is a description of how to make a converter from DIL-42 to PSOP44.
But there shoud be enough pins for this at the MOD40 adapter as well? Right?
(I'm curious since i only own an MOD40 and would like to read/prog the 29F200 if it is possible...)
Herman
Re: MOD40 and 29F200
Postby Dataman (Neil Parker) » 14 Nov 2011 15:28
Hello Herman,
I am assuming your device is a 29F200B? Which manufacturer is it made by?
I believe that you will just need the MOD-44PS adaptor @ £135 and to use the 8bit EEPROM/FLASH library.
Hope this helps.
Return to “Dataman S4”
