New software - Version 3.40
Postby Dataman (Daniel Smith) » 13 Apr 2018 14:37
Added adapter: BGA-Bottom-451
Added adapter: DIL48/PLCC84 ZIF-CS PLD-8
Added adapter: DIL48/QFP100-1.02 ZIF ARM-9
Added adapter: DIL48/QFP100-1.02 ZIF NUC-2
Added adapter: DIL48/QFP64-1.01 ZIF NUC-4
Added adapter: DIL48/QFP64-1.01 ZIF NUC-5
Added adapter: DIL48/QFP64-1.02 ZIF R5F-6
Added adapter: DIL8/BGA12-4 ZIF-CS SFlash-1
Adapter DIL48/QFP112 ZIF HCS12-4, insertion test error fixed
BGA-Top-400 ZIF, corrected name of adapter in device info
Bottom PSOP44 NOR-1 + Top PSOP44 ZIF 600mil, Automatic Yes! bug fixed
