New software - Version 3.40
Postby Dataman (Daniel Smith) » 13 Apr 2018 14:38
Added module: AP1 QFN48-2.02 ZIF TPS53-1
Added module: AP1 QFP100-1.02 ZIF TMPM380-1
Added module: AP1 QFP176-1 ZIF TMS320-2
Added module: AP1 QFP80-1 ZIF TMS320-1a
NXP LPC8xx, added support
Module AP1 QFP80 ZIF HCS12-2, insertion test error fixed
