Programming W27C512 with S4?
Postby Guest » 14 Nov 2011 16:09
Please advise how to program Winbond W27C512 with S4 (if it is possible at all)
I cannot find it in device lists
Code: Select all
>SILICON SIGNATURE Signature: DA08 No match found
There is an application note from Winbond which states that this part is compatible with Dataman products S3 and S4
http://www.winbond-usa.com/products/win ... V01a15.pdf
see page 9
greg
Re: Programming W27C512 with S4?
Postby Dataman (Neil Parker) » 14 Nov 2011 16:10
Hi Greg,
Have you tried manually selecting the device from the library? Hit PROM then use the up and down arrow keys to navigate through the manufacturers and the left right arrow keys to navigated the supported devices under that manufacturer.
You can probably get away with using any generic 27C512 device selection you come across.
Regards
Postby Guest » 14 Nov 2011 16:10
Thanks for your answer
Actually this device is found to be a EEPROM and is programmed with flash library like W27E512 :)
Regards
greg
Return to “Dataman S4”
