S4 with SST 49LF002A
Postby Guest » 14 Nov 2011 16:12
Hi
i have a faulty SST 49LF002A and of couse the S4 says No signature found... (yes i have the adaptor)
my question is if i obtain a new SST 49LF002A will the S4 be able to program it ?
i belived this device to be 3.3volts where others like atmel and winbond are 5volt devices
the spec on the device is listed here
http://pdf1.alldatasheet.co.kr/datashee ... LF002.html
I cannot see it listed in the devices of the current lib of flash eeprom nvram V1.14 but it DOES list the winbond and Atmel 49f series which i think are newer chips, is it the case that the s4 is no longer going to be updated with new libs?
many thanks
Andrew
Re: S4 with SST 49LF002A
Postby Dataman (Neil Parker) » 14 Nov 2011 16:12
Hi Andrew,
The 49LF002A is a low voltage 3.3v device whereas the S4 is strictly a 5v and above programmer. Performing an Auto ID on this device with the S4 is likely to damage it.
I would advise you to look at the Dataman 40Pro on our website as this supports this chip and pretty much all the devices the S4 did and more.
Return to “Dataman S4”
